[ ROM ] Odys Iron CM12.1 LP 5.1.1 custom root firmware (2015/09/20)
damien56
241
2015/11/21 - 15:45
Both have no touch indeed. The stock firmware can be found here: http://www.cube-tablet.com/download/ (direct link below)
http://pan.baidu.com/share/link?shareid=1985753378&uk=288410357
I cannot find the stock 1.06 but both should be rather similar. Both are based on android 4.2.
Thanks Received: 1378
242
2015/11/21 - 15:55
Ok, the touch contoller driver is a kernel module in the build. Install this via CWM: http://crewrktablets.arctablet.com/?wpfb_dl=2726
damien56
damien56
243
2015/11/21 - 17:27
Brilliant. Its working now. No issues with WIFI or Sound. BT does not work, but I dont use it anyway so thats not really an issue.
244
2015/11/21 - 18:55
Fine. Thank you for feedback!
Steve30x
Ireland
Forum Posts: 44
245
2015/11/22 - 10:29
I'm curious here but would this rom work on my tablet? The rom tha came installed on my tablet is very limiting with functionality.
xals1997
246
2015/11/23 - 19:28
I installed the chuwi v88 build on my BQ Edison 2 quad core.
Rotation is working (with the odys iron build it was not working). Everything works perfect, except bluetooth. Camera is working too but there is a problem with the orientation (wrong camera orientation). Youtube sometimes crashes.
This rom is so good and works very smooth. I appreciate so much your work! 😀
I just want to know if there is a way to correct the camera orientation, because camera works but everything is rotated 90º 😛
Appart from that, this is a 10/10 rom, very good job and very good ROM. I've never expected cm12.1 working on my tablet 😀
emil1122
Forum Posts: 20
247
2015/11/24 - 13:15
Hi
I tried install this rom on my medion lifetab 10334 but when i plug device to pc i dont have any usb options on my tablet. Supersu and debugging is enabled. Any help would be appreciated
sindicat21
Forum Posts: 35
248
2015/11/26 - 15:48
emil1122 said
Hi
Just disable usb_debugging and choose MTP connection in settings
emil1122
Forum Posts: 20
249
2015/11/26 - 16:15
I have already solved this problem i have broken usb port thats why my pc doesnt saw tablet
Jammed_Death
Forum Posts: 51
250
2015/12/02 - 19:09
hi, so i have found a notebook with windows 7 and tried to install the rom on a qilive 97r. Put the parameter file for 8gb tablets, installed and the tablet stays black. Panel lights turn on but screen stays black. Nothing start, not even recovery...flashed 2 times...am i missing something? The tablet was restored to working stock rom before flashing
i have to change the loader? the stock rom is jelly bean
Mark06
Forum Posts: 222
Thanks Received: 41
251
2015/12/02 - 19:28
Might be the kernel you flash. Lollipop rom is also jelly bean kernel. Try another kernel (jelly bean).
Jammed_Death
Cube u30gt2 tab
Jammed_Death
Forum Posts: 51
252
2015/12/02 - 19:40
thx...i was using 97r2 kernel and the correct for my tablet is 97r
eckengucker
253
2015/12/03 - 20:56
First of all, thank you for the excellent work!
I got it working on Pipo S3 with:
3.0.36 kernel
160 dpi fix
Pipo S3 fix from 4.4.4 without build.prop.
8 GB parameters
but if I try to enable wifi it reboots itselfs.
Is there a new wifi fix for 5.1.1?
uli-hh
Forum Posts: 31
Thanks Received: 8
254
2015/12/04 - 00:10
rifkin said
rifkin said
Pipo M9 pro has AP6476 wifi. Pls test this as a first guess: http://crewrktablets.arctablet.com/?wpfb_dl=2681
Am I do anything wrong or the patch isn't working as should be?
Do a clean install of build v1.1 and try again: http://crewrktablets.arctablet.com/?wpfb_dl=2696
Hi Oma,
Everything is working like a charm! Thanks a lot!
Finally, I flashed the version 1.1 with the 32 gb parameter and  RK31 Kernel 3036 Hr M9pro Pipo. With the version 2 of the M9 Pro kernel the Rom flash resulted with an error. After the first boot, I tried to turn on the Wifi and Pipo's crashed rebooting every time, so I installed the fix that you post through CWM and now Auto-rotating and Wifi works perfectly. Thanks for your time 🙂
Best regards.
PS: Bluetooth seems not to work, but I don't mind at this moment 😉
Hi Oma
I've tried to install version 1.1 on my PIPO M9 Pro. Coming from Kasty 4.4.2 KiKat-Rom I've changed the loader first. Flashed rom with the 32 gb parameter and the M9pro kernel offered here. But after reboot the touch screen was mirrored in the longitudinal axis. In landscape mode I've to tap on to of the screen for home/back button or in portrait mode I've to tap on left side to select a item on right sight. No wifi and no bluetooth. Installing model fix has no result.
Them I flashed again with the RK31 Kernel 3036 Hr M9pro Pipo 2. This time touch screen worked perfectly. But still no wifi and no bluetooth. Also random reboots when doing settings or starting apps. When tab is gone to sleep modus automatically it does not wake up with power button. I've to reboot. Here is a logcat
I think you are on the right way Oma. Thanks a lot for your great work!
255
2015/12/04 - 19:01
3.0.36 kernel
I am not aware of a 3.0.36+ kernel for this tab.
94 Guest(s)
Devices in use: Desktop (86), Phone (7), Tablet (1)
gerry3818
jaga1986
Piotrassss
mgsppt
inigo
janefonda
