The V88 build.
2015/10/18
Install this via CWM: http://crewrktablets.arctablet.com/?wpfb_dl=2682- Oma -
hi,
i've the same problem as milou21 : bootloop when activate wifi in cube30gt2mh, and try to install the fix via CWM but cannot find the zip file, try both sdcard and external sdcard, always say can't mount sdcard or external sdcard.
thx for advance,
blheng
2015/01/18
Yes, you need to install the V88 build. It is for mt5931 wifi.In TWRP do a fatory reset and install this as a first guess: http://crewrktablets.arctablet.com/?wpfb_dl=2697
Hi Oma..
This didn't work..
Another guess?
cypher007,
About alternative firmwares for the cyclone voyager 2, could you post feedback on the builds recommended by Oma on that topic that you started:
http://www.arctablet.com/blog/forum/pipo-max-m9/cyclone-voyager-2-10-1-need-kitkat/
2015/10/29
hi @Oma7144, I am trying install this rom in my BQ Curie 2 QuadCore WIFI with RK3188 and Jelly Bean but when i tried to turn on the WIFI the tablet reboot. I am using kernel 3.0.36+.
What can i do?
Thank you, your work is awesome.
2013/05/25
zoz said
OK, MT5931 is running now on my rk31board (non high resolution) 😉Can you pls test? http://crewrktablets.arctablet.com/?wpfb_dl=2692
I've just flashed system.img, and wifi looks to be ok, connected to my protected network. I will test with boot.img later. Thanks. What did you change to make authentication work? The wifi module or wpa_supplicant?
Thought this download was for the rk3188 with the wifi problem.
Cube u30gt2 tab
2013/01/02
ok tried KitKat want to move onto lollipop. tried the chuwi v88 rom but it gets stuck on the cr tab loading screen. what nand format tool do I need and what pipo m9 max fix do I need?
also when I tried the KitKat rom I couldn't install much as it restricted me to 4gb. I have a 16gb tab.
2015/11/06
Hi Oma,
First of all, I have to say: Great Work! I never thought my Tablet would ever see Android 5.1. I have a few issues though. The device I have is a Yarvik TAB09-410, which is listed as a Odys Iron Clone. However, the device does not really run smooth, and the results of the Antutu Benchmark are lower than indicated in the screenshots for this ROM (20582 vs 23704, see screenshot). It scores considerably lower on multi core CPU score, and RAM operation. I've tried flashing with both the Kernel that came with this ROM, the Yarvik TAB09-410 kernel on the website, and the kernel included in the Stock-rom by Yarvik, which all yielded similar benchmark results, and user experience. I've also applied the 8GB parameter file, and tried flashing the stock boot-loader instead of the included one, which also changed nothing.
I remember having the same issue while trying the omnirom kitkat ROM a while ago. Also the antutu score on the stock firmware is at around 23000.
Is there anything I'm missing here, or fixes I forgot to apply? Thanks in advance!
2015/11/06
hi oma,
i confirm the installation on the Energy i10 Quad SuperHD. Wifi works perfectly, the camera has the rotation error, but i will try your ucam-ultra-camera app and comment it if run. But I have one problem with the space, this tablet has 16 GB of internal memory, but i flash with one modified parameter that i use in your KitKat Rom for the Aoson M33 and when the tablet boots and i look the storage, i have got only 4 gb for apps, but nothing for other things.
I use the kernel from this original firm http://storage.energysistem.com/archivos/drivers_y_actualizaciones/ekjbejccgbne_FW_Energy_Android_4.2.2_2013_11_04_rev00.zip?0152Kqi36X6AiCMh
thanks for all
2013/05/09
Hi Oma,
I report somes bugs in the V88 build for example, when you turn off the tablet the saved wifi´s passwords disappear, some apps like youtube crash many times and sometimes when you use chrome with several windows or another app with many ram used the tablet restart alone
Sorry for my bad english and great work oma
Thanks!
2014/06/21
Hello Oma,
I have a cube U39GT, which is the cube U30GT's smaller brother. I tried installing your rom using the stock kernel of the cube U39GT and the touch screen does not work for me at all. Im unsure what could be the cause for this not to work, but i hope you could shed some light on this for me. I have been waiting a very long time for a good android 5 rom for my tablet and when I saw what you made I had hope for this tablet again. Without the touch screen I cant supply any logs so I just hope you have an idea.
Thanks!
Sounds like a wrong kernel. Is it an U39GT or an U39GTW? Which kernel do you use?
Also no touch with that kernel? Where can I find the stock firmware?
71 Guest(s)
Devices in use: Desktop (65), Phone (6)
jackthomas
hakhiem
jenom
kfwacky
fer30
culo1
