[ ROM ] Odys Iron CM12.1 LP 5.1.1 custom root firmware (2015/09/20)
Thanks Received: 1378
211
2015/10/14 - 06:35
Boot the tab fresh open the terminal (enable it under development settings) and type:
su
dmesg >/mnt/sdcard/dmesg.txt
perillo
Forum Posts: 16
212
2015/10/14 - 10:40
su
Perfect, download link dmesg BQ edison 2QC https://mega.nz/#!pdx2gKhT!HZuvVTK5D9PHxgp4Jo28oxmJswE_F5oh-Zi_wWIAos4
apog
213
2015/10/14 - 11:08
Hi Oma
Can i flash cm12.1 in ceros revolution rk3188 mt5931?
i tried rom posted in #123 post using stock kernel but tablet doesnt boot..
Can you please help me?
maybe i am flashing wrong kernel?
Thanks.
214
2015/10/14 - 16:28
CT9716? You need to use the JB kernel: http://crewrktablets.arctablet.com/?wpfb_dl=1570
When currently running KK make sure to change the loader first.
bseixas
Forum Posts: 23
215
2015/10/14 - 18:49
su
Thanks 😀
I sent PM with dmesg.txt file as requested. 😉
217
2015/10/14 - 19:25
perillo said
I flash this and screen rotation works fine, but the camera is rotated in the other side
I use the 3.0.36+ stock kernel, this . I try to get the dmesg and send to you
Download again and try: http://crewrktablets.arctablet.com/?wpfb_dl=2705
bseixas
Forum Posts: 23
218
2015/10/14 - 19:44
Try again: http://crewrktablets.arctablet.com/?wpfb_dl=2707
Still no sound and no bluetooth.
EDIT:
Does it make a diference to make a factory reset after aplying patch?
219
2015/10/14 - 20:25
I am running out of ideas. Sorry.
apog
220
2015/10/14 - 21:01
yes. CT9716
This is the kernel i use and i also change the loader but tablet doesnt boot. it shows only in the beginning the android logo for 3-4 seconds and then nothing..
any ideas?
bseixas
Forum Posts: 23
221
2015/10/14 - 21:15
Frown
It is a shame.
Not for the bluetooth issue but for the no sound problem, my kid plays games on this tablet and with no sound it is dificult to keep it like this, the rest works really smooth and with no stability issues.
I tried a factory reset after patch and now AudioFX app force closes, is there a way to try other sound library (app) with a patch using CWM?
perillo
Forum Posts: 16
222
2015/10/14 - 23:59
I try this but i can't flash, i get an error "installation aborted" but don't worry camera isn't important for me
apog
223
2015/10/15 - 13:16
i tried to flash Odys Iron cm12.1 from first post and the rom installed succesfully.. of course its laggy and no wifi and bluetooth as it uses mt5931 chipset...
Why i cant install rom from post #123?
I need your help @Oma !!
224
2015/10/15 - 19:47
Yes, you need to install the V88 build. It is for mt5931 wifi.
In TWRP do a fatory reset and install this as a first guess: http://crewrktablets.arctablet.com/?wpfb_dl=2697
apog
225
2015/10/15 - 20:40
i will flash this after flashing the odys iron rom or the  rom from post #123 for v88?
91 Guest(s)
Devices in use: Desktop (87), Phone (4)
gerry3818
jaga1986
Piotrassss
mgsppt
inigo
janefonda
