[ ROM ] Odys Iron CM12.1 LP 5.1.1 custom root firmware (2015/09/20)
truongvantuan
181
2015/10/10 - 05:48
Install this as a first guess via CWM: http://crewrktablets.arctablet.com/?wpfb_dl=2684
thanks oma. it was working so good
milou21
182
2015/10/10 - 09:43
milou21 said
I test this firmware 5.1.1 on my cube U30GT2 but when I want to turn on the wifi, the tablet start and restart again and again (bootloop).
Which build and kernel?
Hi.
U30GT2 : Kernel : 3.0.36+ (http://crewrktablets.arctablet.com/?wpfb_dl=818.) and build 5.1.1 v1.1
Many thanks.
Thanks Received: 1378
nyusti
184
2015/10/10 - 10:33
Hi Oma!
What kernel should I use to pipo m9max?
Thx
185
2015/10/10 - 11:02
Pipo M9 max has MT5931 wifi. So, pls use the V88 build (see post #123).
Here is the kernel. http://crewrktablets.arctablet.com/?wpfb_dl=740
nyusti
186
2015/10/10 - 11:58
Pipo Max M9-on works perfectly the V88 build (except Bluetooth) with the following kernel:
http://crewrktablets.arctablet.com/?wpfb_dl=1440
build.prop was rewritten to: ro.sf.hwrotation = 180 to 270
Thx Oma!
187
2015/10/10 - 17:21
Fine. Thank you for feedback!
Mark06
Forum Posts: 222
Thanks Received: 41
188
2015/10/10 - 17:23
@oma7144: why is the cyanogenmod 12.1 so very slow on the cube u30gt2. It has a 1.8 ghz quad core which is much faster than my samsung 1.8ghz one-core, still it's working much faster on the samsung then it is on the cube. This is a bit weird right? Then cyanogenmod build 1.1 has wifi troubles where build 1.0 doesn't have them. Seems like there is another driver in the latest build for wifi.
thx for the reply!
grtz,
Mark06
Cube u30gt2 tab
189
2015/10/10 - 17:40
Look & Feel is ok in my opinion. LP usually works on a 3.10.0 kernel or later. To make it work on an older kernel we need to backport a lot of stuff to older API's.
The RK903 kernel module could crash against the different kernel. So, it is good to document the right kernel for the build. Pls check the latest model fix, which does include the module.
karmantyu
190
2015/10/11 - 11:43
Dear OMA,
Thank You for the great LP ROM for M6 pro, it is running as expected.
However there is a newer JB kernel #227 instead of #213 available for M6 pro.
Please find the untouched #227 kernel attached.
There is also a patched low voltage variant for brave people 🙂
The following users say thank you to karmantyu for this useful post:
191
2015/10/11 - 11:50
Fine. Thank you for feedback and sharing!
Cytryn
Forum Posts: 35
Thanks Received: 4
192
2015/10/11 - 15:08
CM12.1_rk31_002.jpgImage Enlarger
What movie player is on this screen? I cant find this one.
193
2015/10/11 - 15:29
GPlayer
Cytryn
perillo
Forum Posts: 16
194
2015/10/12 - 23:21
Hi Oma
i confirmed that V1.1 build Chuwi V88 works in a BQ Edison 2 QC, works fine but bluetooth not working , the camera is rotate and screen rotation works but inverse, can you help me to solve this?
Thanks and great work
bvlet
195
2015/10/13 - 04:03
Forgive me if this is a really stupid question, but I can't seem to find a clear overview of what's possible and what not.
I have an older Teclast P88HD Tablet with Rockchip RK30566 processor and android 4.1.1. Kernel is 3.0.8+.
It's rooted and runs CWM recovery.
Would it be possible (with some work) to run this Lollipop firmware on that tablet? Ans if not, what's preventing it from happening?
Thanks in advance for your reply!
95 Guest(s)
Devices in use: Desktop (87), Phone (7), Tablet (1)
gerry3818
jaga1986
Piotrassss
mgsppt
inigo
janefonda
