[ ROM ] Odys Iron CM12.1 LP 5.1.1 custom root firmware (2015/09/20)
Rock293031
Forum Posts: 39
166
2015/10/07 - 13:52
We faced the same issue with the KK build. So something is different with your kernel (non-standard call of mali or ump).
However, what is the result for your RK3066 Imux TX12D? Build will boot on it's 3.0.36+ kernel.
Hi Oma,
yes, it is the same issue like the one we had with all KK builds.
Also playing around with wm size and wm density does not help.
I can change the resolution, the screen flickers for 1sec. but remains distorted.
I have no idea where to start. I have the Kernel Source for the tab but i have no idea what to change.
My TX12D is dead. It is permanently in MaskMode. The Nand had many, many errors.
I will ask my brother if he wants to update his TX12d, or my dad.
I still have a Pipo M1 (Odys Noon der 1sten Generation) and will try this one also.
But i can have these devices only next week.
Thanks and regards
Neptune
arabi48
Forum Posts: 48
167
2015/10/08 - 13:44
hi oma
after the erase idb and flash 1.24 loader the nand become 6141 BEFOR it 8191 is it normal
chojin
168
2015/10/08 - 14:30
Hello @ALL I have a ODYS Ieos 10 Quad pro, which has the RK3188 Chip and it runs with 5.1.1 ...
It's my first "Cheap" Tablet and for the moment i'm a little confused...
There are a lot of RK and Iron and what ever.
Can I flash the ROM on my Device?
Is there any CWM or TWRP for this device with 5.1.1?
PS: for a push in the right thread / area I would be very grateful
greetings Chojin
Hallo an ALLE Ich habe ein ODYS Ieos 10 Quad Pro, welches den RK3188-Chip hat es läuft aktuell auf 5.1.1...
Es ist mein erstes "BILLIG" Tablet und im Moment bin ich ein wenig verwirrt ...
Es gibt eine Menge von RK Iron und was auch immer.
Kann ich die ROM auf meinem Gerät flashen?
Gibt es eine CWM oder TWRP für dieses Gerät mit 5.1.1?
P.S.: für einen Push in den richtigen Thread / Bereich wäre ich sehr dankbar
Grüssle aus dem Schwabenland   Chojin
Thanks Received: 1378
170
2015/10/08 - 17:19
What do you mean? Is the build booting now?
chojin
171
2015/10/08 - 19:14
So bitte hoffe das hilft weiter
172
2015/10/08 - 19:20
http://www.odys.de/web/tablet-pc_ieosquad10pro_de.html
Allwinner A33. Wirst du hier bei Arctablet nicht finden. Schau dich mal bei XDA um.
chojin
milou21
173
2015/10/08 - 21:45
CM12.1 has landed on Cube U30GT2 😉
Thanks to Mark06 for testing!
Use a non selinux kernel, i.e. this very old JB one (change in folder rockdev/Image): http://crewrktablets.arctablet.com/?wpfb_dl=818.
Change this parameter file for 32GB NAND in folder rockdev.
For the moment install this via CWM to correct the rotation manually.
If you are on a KK/selinux build, make sure you change the loader first (see post #1)!
CM12.1-on-Cube-U30GT2-1.pngImage Enlarger
Hi.
I test this firmware 5.1.1 on my cube U30GT2 but when I want to turn on the wifi, the tablet start and restart again and again (bootloop).
I don't know why.
Many thanks for your work OMA.
arabi48
Forum Posts: 48
174
2015/10/09 - 01:01
yes boot but like the previews version very lagy i cant use my tab
i feel like my tab has just 1 cpu not quad Cry
what the probleme what meens 8191 OR 6141 !
175
2015/10/09 - 08:54
Gen1 and gen2 loader have diffent write buffer, so that's "normal". Did you use the Condor kernel?
176
2015/10/09 - 08:57
Which build and kernel?
Mark06
Forum Posts: 222
Thanks Received: 41
177
2015/10/09 - 16:53
Turn wifi on and the cube reboots. Had that too. Cube u30gt2, any jb kernel, build 1.1 cyanogenmod 5.1.1. Further you can't use the build 1.0 parameter file for the build 1.1, flashing the image.bin gives an check error and quits the flash process. You have to use the given parameter file with build 1.1.
Cube u30gt2 tab
arabi48
Forum Posts: 48
178
2015/10/09 - 17:10
YES
truongvantuan
179
2015/10/09 - 19:44
Yeah, there are no RK driver for Win10.
How to active wifi for AP6210? i using CM 12.1
180
2015/10/09 - 23:33
Install this as a first guess via CWM: http://crewrktablets.arctablet.com/?wpfb_dl=2684
94 Guest(s)
Devices in use: Desktop (86), Phone (7), Tablet (1)
gerry3818
jaga1986
Piotrassss
mgsppt
inigo
janefonda
