Gents,
CM12.1 has landed on Odys Iron 😉
IRON by CrewRKTablets CM12.1 LP 5.1.1 build v1.1
IRON by CrewRKTablets CM12.1 LP 5.1.1 build v1.0
– generation 1 loader
– selinux off
– CWM 6.0.3.1 recovery
– system ext4
– homebrew kernel jk #1
– unified internal storage
– screen 280 dpi
– ethernet support
– init.d support
– gameloft compatible
– USB-Hub enabled
– Reboot Menue
not working: ./.
Add more codecs (3gp, avi, wmv, flv) - install via CWM: http://crewrktablets.arctablet.com/?wpfb_dl=2775
flash instructions are included in the download pack.
if you are on a gen2 loader firmware (KitKat) change the loader first.
hints:
- to improve UI feeling: disable all animation scales in developer options,
...use Nova launcher and set animation/scroll to "faster than light" and
...enable Entropy Fixer with value 256
- to improve battery drain set keep wi-fi on during sleep to never
- Oma's favourite apps for LP
- Xposed Framework test pack
Special thanks to mussonero & netlars!
– Oma -
damien56, primus, SemnonePer aspera ad astra, we rock the Tablets !
CM12.1 has landed on Cube U30GT2 😉
Thanks to Mark06 for testing!
Use a non selinux kernel, i.e. this very old JB one (change in folder rockdev/Image): http://crewrktablets.arctablet.com/?wpfb_dl=818.
Change this parameter file for 32GB NAND in folder rockdev.
For the moment install this via CWM to correct the rotation manually.
If you are on a KK/selinux build, make sure you change the loader first (see post #1)!
milou21, damien56Per aspera ad astra, we rock the Tablets !
2015/09/22
can I install this rom to Snakebyte vyper 7 3188?
- Display: 7-inch 1280x800 IPS display
- Processor: 1.6GHz RK3188 quad-core Rockchip A9
- RAM: 1GB
- Storage: 8GB, microSD card slot
- Cameras: 5MP rear shooter, 2MP front
- Ports: microUSB x2 (one charging, one data transfer), microSD, miniHDMI, headphone jack
- Wireless: 802.11 a/g/n, Bluetooth 4.0
2015/03/18
You can try, you need jellybean kernel 3.0.36+ from you stock 4.2.2 replace it (more info in download pack) and use parameter for 8gb nand tablets:parameter for 8 GB tabs(replace it in rockdev folder) and flash (look in instruction). After boot to CWM you need do factory reset and install 160 dpi fixand reboot.
2015/03/18
There is mistake in Oma's 160 dpi fix
In build.prop in line : ro.sf.lcd_density=16 should be ofc ro.sf.lcd_density=160
2015/03/18
Managed to run this build, with some replacment and im surprised ethernet now working and seams those 3 modules are same like in CM12 build. Anyways same issues with camera turned and bluetooth not working like in CM12 and didnt manage to fix those.
Any tips about camera app which i can use with turn screen option or something?
Im trying with mussonero fix 3G in his version CM12.1 and so far we manage one thing: i can turn mobile network, set apn and search/see and register to right mobile operators, but no signal icon and no working internet connection.
With Odys Iron CM12.1 i coudnt manage to even turn mobile network on. Tried my stock and other libril-rk29-dataonly.so files.
Im gonna test more mainly this rom stability -reboots, freeze etc.
The question is, what tab is it? In the other thread you mentioned it is a M33Q GB?
Cytryn said
Managed to run this build, with some replacment and im surprised ethernet now working and seams those 3 modules are same like in CM12 build. Anyways same issues with camera turned and bluetooth not working like in CM12 and didnt manage to fix those.Any tips about camera app which i can use with turn screen option or something?
You should mention, that you boot this build on a rk30board (Kiano Core 10.1 Dual 3G, 3.0.36+ kernel) 😉
Workaround for cam: http://forum.xda-developers.com/showpost.php?p=46671244&postcount=804
Let me have the model fix when you are finished.
CytrynPer aspera ad astra, we rock the Tablets !
2015/03/18
Thanks for camera app info.
Here is fix for Kiano Core 10.1 Dual 3G with 3.0.36+ stock kernel (rk3066 tab): Odys_Iron_CM12.1_LP_5.1.1_sensor_wifi_fix.zip, just wifi, dpi, rotation fix, for camera use Oma's workaround in previous post. Still needs to fix 3G and BT.
83 Guest(s)
Devices in use: Desktop (71), Phone (12)
PATRYK-VP
victorialp23
alertscam
aolmail7448
Arc123456789
forty42
