[ ROM ] Odys Iron CM11 4.4.4 custom root firmware (2014/07/26)
Thanks Received: 1376
2014/08/15 - 22:37
SquareMan said
Pipo Max M9 Pro dmesg.txt
Ok, Pipo M9 pro has AP6476 wifi. Check out the latest Omni v1.4 build: http://crewrktablets.arctablet.com/?p=3555
Use this model fix: http://crewrktablets.arctablet.com/?wpfb_dl=2010
SquareMan
jastaz23
Forum Posts: 28
2014/08/16 - 01:31
Sorry my mistake V1.1 is 4.4.4, the numbers change because of the build prop fix included in the 160 dpi is from 4.4.3....
Confirmed installation on Pipo U8!
Thanks Sir Oma!
jastaz23
Forum Posts: 28
2014/08/16 - 19:00
Hi Sir OMA , we tried this on M7pro , using the M9pro fix http://crewrktablets.arctablet.com/?wpfb_dl=2010
Bluetooth is not working but tablet boots fine , rotation is working, camera is working... attached is the dmesg for M7 Pro sing this ROM V1.1
2014/08/16 - 19:22
Pipo M7 pro has also AP6476 wifi. Can you pls test with Omni v1.4, which is much more complete? Results will help in CM11 development.
2014/08/16 - 19:24
Thanks Sir Oma!
Same here. Pls test Omni v1.4 build with this fix: http://crewrktablets.arctablet.com/?wpfb_dl=2017
jastaz23
Forum Posts: 28
2014/08/16 - 19:33
wifi, rotation camera viewfinder works on M7pro using the M9pro Model fix, but bluetooth doesn't, and also the Auto brightness it didn't work both on Pipo U8 and M9pro...
On my U8 I'm testing the Omni V1.4 will use that fix now,  will  post dmesg  or other issues found on its thread,
Thanks sir Oma!
Metallic2011
2014/10/03 - 13:24
Hello Oma. I'm trying to port Your CM11 for Ritmix RMD-785(well, almost Chuwi v88, only bluetooth I can't check because of his lack Ritmix RMD-785).
I flashed your firmware CrewRKTablets_Odys_Iron_CM11_4.4.4_v1.1 using loader 1.24 and parameter from Oma_KK_4.4.4_v2.4_gen1 loader.
The kernel and the files for the substitution took from your firmware Oma_RK31_Chuwi_V88_CM10.1_4.2.2_v1.3.2a. After the tablet was loaded, but systemUI all the time out with an error and the screen was all great.
Then I installed CrewRKTablets_RK31_KK_CM11_v1.0_160dpi and got a well working system with no wi fi and other things-as the camera and rotate. The most frustrating it is Wi-fi.
Please tell me how to fix Wi Fi(I mt5931).
I was selecting section system.img and section boot.img and saw that support mt5931 in both sections. But wi fi is not working(not included). Tried to replace the files:
system\lib\modules
kwifi.ko
system\lib\modules\wlan.ko
system\lib\hw\camera.rk30board.so
system\lib\hw\sensors.rk30board.so on the same from firmware Oma_RK31_Chuwi_V88_CM10.1_4.2.2_v1.3.2a rotate operate properly. The situation with wi fi has not changed.
If you want I can provide logs, dmesg and logcat.
Thanks in advance for your help.
2014/10/03 - 13:29
Well, I have myself a tab with MTK5931 wifi. We cannot make this work since month now. I am frustrated, too.
Try one of the V88 builds and use Xposed Framework to add functionality.
Metallic2011
2014/10/03 - 13:45
Thank you Oma for your work. I hope you will succeed to overcome the compatibility issue CM11 and Mt5931. I wish you good luck and grateful user of your firmware.
The following users say thank you to Metallic2011 for this useful post:
Jammed_Death
Forum Posts: 51
2014/11/15 - 20:00
can i install this instead of the omni on qilive 97r? procedure is the same?
2014/11/17 - 10:21
Should be work in the same way. Pls start only with changing the kernel. Latest build v1.2 has an unified internal storage. So just do a factory rest after first boot into CWM.
95 Guest(s)
Devices in use: Desktop (90), Phone (5)
lee662
gilcamtz
moroco66
shawner82
dima57
NOLF110
