[ ROM ] Odys Iron CM11 4.4.4 custom root firmware (2014/07/26)
2014/08/10 - 22:47
Gents,
KTU84Q (Android 4.4.4) has landed on Odys Iron ;-)
IRON by CrewRKTablets CM11 4.4.4 beta build v1.1
generation 1 loader
selinux off
– CWM 6.0.3.1 recovery
– system ext4
homebrew kernel jk #1
unified internal storage
– screen 264 dpi
– PhabletUI & Multi-User
– ethernet support
– init.d support
– gameloft compatible
– USB-Hub enabled
– Dateimanager HD (Root)
– Nova Launcher
, Google Now Launcher
issues:
– MP3 encoding
Special thanks to netlars & JochenKauz
– Oma -
cm11-has-landed-on-Iron_12-1.pngImage EnlargerCM_v1.1_02a-1.pngImage Enlarger
CM_v1.1_01.jpgImage Enlargercm11-has-landed-on-Iron_3-1.jpgImage Enlargercm11-has-landed-on-Iron_5-2.pngImage EnlargerCM_v1.1_03.pngImage Enlarger
jastaz23, XXX-Man
cftmartins
2014/08/11 - 12:53
I install this rom on my Qilive97r and the process went well.
But the wifi and autorotation doesn't work.
When I enable wifi it reboot automatically.
CM
SquareMan
2014/08/11 - 13:24
Hi!
This firmware will work on Pipo Max M9 Pro?
2014/08/11 - 16:46
Pls provide a dmesg log.
2014/08/11 - 17:05
Build is for RTL 8723 wifi. Qilive 97r has RK903 wifi. Check out the OmniRom model fix as I first guess: http://crewrktablets.arctablet.com/?wpfb_dl=1896
cappybob
Forum Posts: 79
Thanks Received: 8
2014/08/11 - 23:42
Up and running on Radxa, the display changer worked, will need to reboot after one uses it??  I had too, to get the display to sharpen up.  Wifi works on this build.  Built with the JB kernel, the Selinux kernel would not build.  I guess that would be a question;  JB or Selinux Kernel.
later and thanks to the crew---cappybob
shapipoy
2014/08/12 - 02:32
does this work on my U9GTV ?? please help
2014/08/12 - 16:05
2014/08/12 - 16:06
Selinux is off. So build works on any JB kernel.
cappybob
SquareMan
2014/08/13 - 08:28
Pipo Max M9 Pro dmesg.txt
nelySLB
Forum Posts: 34
2014/08/14 - 00:10
this works on U30GT2 ?
Rock293031
Forum Posts: 39
2014/08/14 - 01:21
Hi Oma,
die ROM läuft auf meinem RK3066 IMUZ TX12D sehr gut.
Gleich nach dem Start kommt der FC "Exchange Dienste wurde beendet".
RK903 WIFI/BT, Rotation, Cameras mit Model Fix und build.prop rotation zum Laufen gebracht.
11.200 Punkte bei Antutu. Mit Chuvi V88 2.4 build hat das Tab 12.800 erreicht.
Alles in Allem Stabil und Flüssig.
Grüsse, Neptune
jastaz23
Forum Posts: 28
2014/08/14 - 17:08
v1.1 is still on 4.4.3? my rotation is inverted.. on pipo U8...
Rock293031
Forum Posts: 39
2014/08/14 - 19:33
@ jastaz23:  please try to add a new line to build.prop
ro.sf.hwrotation=90 or 180 or 270  (the correct value you need to find out, but i assume 180)
@ oma: nach einem Tag hat sich Antutu auf 12.100 Punkten eingependelt :)
jastaz23
Forum Posts: 28
2014/08/14 - 20:16
Screenshot_2014-08-15-18-08-28-1.pngImage Enlarger
So even the V1.1 build is also 4.4.3?
For Pipo u8
(since U8 doesn't have volume buttons i used a working twrp for JB U8, sourced from other forum)
Wifi and Bluetooth Fixed -  flashed via twrp the following file fixes
*CrewRKTablets_KK_4.4.2_Iron_v1.2_model fix_Qilive 97r
*CrewRKTablets_KK_Omni_v1.3_model fix_AOC_Q70S15
Camera Fixed - flashed via twrp
*CrewRKTablets_KK_4.4.2_Iron_v1.0_camera_fix
Mp3 Fixed installed poweramp from playstore (even the free one works)
Auto Rotation Fixed - edit build prop. add lines - ro.sf.hwrotation=90 or 180 or 270 (180 works for inverted)
Stilled bugged:
*Missing Emoji on android keyboard (emoji tab is blank, had to use a keyboard from playstore which is ugly btw, hopefully the stock keyboard gets fix too I'm used to it)
@Rock293031
Your build prop tweaks works pefectly! thank you!
Sir Oma thanks for this!, Smooth so far, but will have to try your Omni 4.4.4 same issues so it should need same fixes...
77 Guest(s)
Devices in use: Desktop (72), Phone (5)
