[ ROM ] Odys Iron CM11 4.4.3 custom root firmware (2014/06/07)
jastaz23
Forum Posts: 28
2014/08/10 - 12:59
logcat from my U8, is this it? I used logcatx from app store....
2014/08/10 - 22:28
No, this is Android. I'd like to see your hardware.
To do a dmesg you can use tools like this: http://forum.xda-developers.com/showthread.php?t=1944776
jastaz23
Forum Posts: 28
2014/08/10 - 22:44
I know it's android I'm using a Pipo U8 that log is from logcatx app from playstore, I'm still figuring out how to use this AIOlog..
jastaz23
Forum Posts: 28
2014/08/11 - 15:49
Hi sir Oma, I've already flashed this rom on my Pipo U8 and it boots fine I followed the instructions I read on switching from Gen2 loader back to Gen1, after that what I did is I used a JellyBean kernel from my previously used rom and a Stock JellyBean recovery to format data/cache at first boot since CWM is not working for Pipo U8 as U8 doesn't have Volume Buttons, after it boots to to Homescreen I flashed a generic TWRP (1024x600 reso) for JellyBean and touch on twrp works fine, I did not flashed the 160dpi fix since the screen is already on 160dpi (maybe from the kernel I used) ad the display and touches is working really good. That UI on this is really fast and smooth wifi connects really fast , It was a smooth install and a smooth rom until I experience some bugs...
Now here's the problem...
-Camera view finder is Inverted (viewfinder only not the UI
-Sensors not working (gravity, gyro, proximity etc..) only sound sensor is working (mic)
-Bluetooth doesn't work
-MP3 doesn't play
that is all the bugs and issues I can find, I can't seem to make aiolog work on my pc, I dont know why, so I can't provide you a logcot or dmseg... Is it possible to do a dmseg log from terminal emulator?
Also, I was not able to see that you have a 4.4.4 version of this, I will be downloading it and see if that one has no bugs and issues like this on 4.4.3..
Hopefully you can provide a fix for this if possible :) alot of U8 users from our group have been wanting this I was the first one to test on our group and the Installation was smooth also the this Rom is really fast hopefully there can be a fix for the sensors, camera and mp3 bugs, I was not able to test if the mini-HDMI is working though..
Thank you sir for all your hard work!
I also tested your "RK31: V88 by Oma – KitKat 4.4.4 Edition" with the same procedure, boots fast, UI is fast but almost same Issues , and also Wifi doesn't work on that rom on my Pipo U8 :(
2014/08/11 - 16:45
Ok, check out the v1.1 build and give feedback in the other thread.
jastaz23
Forum Posts: 28
2014/08/11 - 16:48
will do Sir, thanks!
sadly for the V88 4.4.4 though .... hehe
57 Guest(s)
Devices in use: Desktop (54), Phone (3)
yuuma
dima1965
Денисен88
Romanmob
reisender_androit
callmemax
