[ ROM ] Odys Iron CM11 4.4.3 custom root firmware (2014/06/07)
2014/06/08 - 11:41
Gents,
KTU84M (Android 4.4.3) has landed on Odys Iron ;-)
IRON by CrewRKTablets CM11 4.4.3 beta build v1.0  & format_NAND_KK (MANDATORY, install via CWM)
generation 1 loader
– CWM 6.0.3.1 recovery
– system ext4
homebrew kernel jk #1
unified internal storage
– screen 320 dpi
– PhabletUI & Multi-User
– ethernet support
– init.d support
– gameloft compatible
– USB-Hub enabled
– Dateimanager HD (Root)
– Nova Launcher
, Google Now Launcher
issues:
– tab may need to reboot to enable wifi
– full hw decoding support
Special thanks to netlars & JochenKauz
– Oma -
cm11-has-landed-on-Iron_12.pngImage Enlarger
cm11-has-landed-on-Iron_7.pngImage Enlargercm11-has-landed-on-Iron_4.pngImage Enlargercm11-has-landed-on-Iron_3.jpgImage Enlargercm11-has-landed-on-Iron_2.pngImage Enlargercm11-has-landed-on-Iron_8.pngImage Enlargercm11-has-landed-on-Iron_9.jpgImage Enlargercm11-has-landed-on-Iron_11.jpgImage Enlargercm11-has-landed-on-Iron_14.pngImage Enlarger
LolloPS, admin
LolloPS
Forum Posts: 28
2014/06/09 - 10:45
Hi Oma i tried this rom on my mediacom m-mp84s4 and it has the exact same issues of the OmniRom 4.4.2 that i explained in the mediacom thread.
How is going the work to fix these problems?
PS= thank you for your work !!!!!!!!!!!...these roms are giving new life to these devices!! :)
PS= for the video decoding problem i tried to copy all the "libstagefright" files from a samsung galaxy s2 cm11 4.4.3 rom (it has a mali 400 )the tab started but the hw decoding stopped to work in all types of video lol ...well... it was worth trying Laugh
2014/06/09 - 16:02
Yes, hw decoding issue is driven by libstagefright. RK patched these libs dramatically. There is a lot of work to merge code into CM11.
hadeskaiser
2014/06/19 - 07:59
hi i can not install the rom into my n90fhdrk.cwm cannot display.
2014/06/19 - 08:10
Here is the kernel: http://crewrktablets.arctablet.com/?wpfb_dl=1598
Flash again incl. eraseIDB.
hadeskaiser
2014/06/19 - 09:10
i intsall this kenel, now the system can work.
but wifi and Gravity sensor do not work。
i can not Rotary screen orientation.
2014/06/19 - 09:53
Enable wifi and reboot.
hadeskaiser
2014/06/19 - 10:35
i have enable wifi and reboot.but still can not work
2014/06/19 - 10:41
Yeah, it's still a problem. Try to enable BT and reboot.
hadeskaiser
2014/06/19 - 10:50
i do enable BT and reboot
and bt and wifi still not work. and i can not change screen orientation
2014/06/19 - 10:54
Can I have a dmesg and a logcat log?
hadeskaiser
2014/06/19 - 10:59
sorry i have already flash my n90fhdrk use crom2.3.
livendead
2014/07/12 - 03:02
Confirmed,
   working on "Aoson M30Q" with my backed up 'stock JB kernel' (RK3188)!
It uses boot-loader version 1 (v1.24), from my Jelly Bean 4.2.2 stock ROM.
Minor errors; rotation (auto-rotation - missing sensors), and mini-HDMI output (HDMI - Settings missing from system).
Great work everyone contributing, look forward to the future!
Regards,
Livendead
jastaz23
Forum Posts: 28
2014/08/10 - 06:37
Hi sir Oma can I use this for Pipo U8? do I need a particular kernel?
2014/08/10 - 12:19
Pls provide a dmesg log.
57 Guest(s)
Devices in use: Desktop (53), Phone (4)
