Gents,
This is KitKat build for Odys Iron, finally with full hw-decoding support
IRON by Oma KitKat build v1.2Â & format_NAND_KK (MANDATORY, install via CWM)
– generation 1 loader
– CWM 6.0.3.1 recovery
– system ext4
– homebrew kernel jk #1
– internal storage 4,0 GB
– device spoofed as Nexus 7
– PhabletUI & Multi-User
– ethernet support
– init.d support
– gameloft compatible
– USB-Hub enabled
– Dateimanager HD (Root)
– Nova Launcher
hints:
- do not install google+ from Play Store; use this one (can be updated later)
- go to settings/performance and set CPU mode to normal
- to improve UI feeling disable animation scales in developer options
- to improve battery drain set keep wi-fi on during sleep to never
- to get full access to the build enable /system rw in File Manager HD
- to disable su notifications change notification in su app
- to prettify the build use Xposed Framework > Starterpack
– Oma -
PrEziPer aspera ad astra, we rock the Tablets !
2014/06/06
Many thanks OMA !Â
Works like a charm !!Â
P.S. I was not able to flash the Tablet under three different Windows 8.1 machines -- the bootloader was "stuck" in a recognizing loop (USB Device was not recognized). My only solution was to use a fourth -- Windows 7 Laptop and this time it was a piece of cake. I have found a workaround that was posted on slatedroid - unfortunately - for me it didn't work. But here is the link in case some1 has similar problems >Â
http://www.slatedroid.com/topic/95578-rockchip-flashing-does-not-work-with-win81/
2014/06/06
Ok, after a few hours of testing -- not so flawless... The UI is sluggish and not fluent...
It has some very weird behaviours... and was unable to narrow it down to anything...
Btw - the CPU Tweaker that is included is influencing the settings in performance / cpu mode. That is why I have thrown it away and replaced with no-frills.
I think I will wait for a version of OMNI and/or CM based on KK that is less buggy and then I'll upgrade to it.
88 Guest(s)
Devices in use: Desktop (76), Phone (12)
Nursat
MaXXWar
adison
Zenn
nicl
FreddyBerlin
