Gents,
this is a generation 2 loader build for Nextbook 8 Quad Core NX785QC8G. Wifi chip is RTL8188
Nextbook 8 QC by Oma KK 4.4.2 build v2.1
Nextbook 8 QC by Oma KK 4.4.2 build v2.0
– system ext4
– kernel yunyan #37
– internal storage 2 GB [v2.0]
– internal storage 4 GB [v2.1]
– extrenal sdcard mounted as NAND [v2.1]
– device spoofed as Nexus 7 [v2.1]
– ethernet support
– init.d support
– gameloft compatible
– USB-Hub enabled
– Dateimanager HD (Root)
– Nova Launcher
Instructions are included in the download pack.
hints:
- to improve UI feeling: disable all animation scales in developer options,
- use Nova launcher and set animation/scroll to "faster than light" and
- enable Entropy Fixer with value 256
- to improve battery drain set keep wi-fi on during sleep to never
- to get full access to the build enable /system rw in File Manager HD
- to disable su notifications change notification in settings/SuperSu
- to prettify the build use Xposed Framework > Starter Pack
- to enable multi-user use the Xposed module Multi Users
Thanks to perfectpitch for providing the firmware and testing.
TehLexinator, PakkaV, SwedePer aspera ad astra, we rock the Tablets !
2014/07/16
I tried to flash the rom to my Nextbook 8 Quad Core NX785QC8G 7.85" tablet using RKBatch tool v1.7 but i had to first get into bootloader mode with cydia impactor in order for it to recognize my tablet. I first tested another Rom which bricked my device but was able to quickly restore with a KitKat 4.4.2 stock rom I had downloaded. When I tried loading your file I got an error message which said "failed to load firmware" any suggestions
2014/07/16
ok I'm a noob at this, so I tried it again...carefully reading your instructions posted elsewhere after several attempts I successfully flashed my Nextbook 8 7.85" on KitKat 4.4.2 with v.1 two draw backs..no wifi and my model came up as a Nexus. couldn't leave well enough alone so I started over and ErasedIDB as well as flashed the Kernel you provided but this time using v.2 and when the tablet rebooted into recovery, I wiped the cache and data under advanced options. It gave me a choice to disable flash recovery and I chose yes. on the following page it gave me a choice to fix ROOT access and I choice yes. on reboot its looping at the OMA screen...what did I do wrong?
Download the pack from post #1. Instructions are included. Flash again incl. eraseIDB. Let the stock recovery format the user partitions. Later you can flash the CWM (both answers are NO).
Goto settings/About the tablet. Tab 5 times onto the Build-Number.
The bridge is just the java part. Update the Xposed Installer.
Update post #1 with build v2.1.
The tabs bottleneck is the 8 GB NAND. So, I changed the mount points which will make up to 32 GB space available for apps and app data. The internal storage is now 4 GB. Also I touched the footprint of the build to make it wide compatible for apps in the Play Store.
Try again incl. eraseIDB.
81 Guest(s)
Devices in use: Desktop (74), Phone (6), Tablet (1)
StatusQ
helloyuen
melcis
nelcis
sophiajohnson87
Brainticket
