Gents,
this is a generation 2 loader build for Nextbook 8 Quad Core NX785QC8G. Wifi chip is RTL8188
– stock 4.2.41 recovery, CWM 6.0.3.1 recovery
– system ext4
– kernel bryan #570
– internal storage 2 GB
– Multi-User
– ethernet support
– init.d support
– gameloft compatible
– USB-Hub enabled
– Dateimanager HD (Root)
– Nova Launcher
Instructions are included in the download pack.
A few hints:
- higher performance > disable animation scales in developer options
- battery drain > set keep wi-fi on during sleep to never
- full access to the build > enable /system rw in File Manager HD
- don't show su notifications > disable in Superuser
- to prettify the build use Xposed Framework > JB Starter Pack
Thank you for feedback! There is a also a KK rom with swapped mounts: http://www.arctablet.com/blog/forum/crewrktablets-rk3188-entwicklung-customroms-development-croms/rom-nextbook-8-quad-core-nx785qc8g-android-4-4-2-custom-root-firmware-20140713/?lang=fr
61 Guest(s)
Devices in use: Desktop (46), Phone (15)
cutierogue
hans41
