[ ROM ] Monster Tab 9.7 JB 4.2.2 custom root firmware (2015/02/21)
2015/02/21 - 17:01
Gents,
This is a build for Monster Tab 9.7". Tab has MT7601u wifi ;-)
Monster Tab by Oma JB build v1.0 & format NAND
- CWM 6.0.3.1 recovery
- system ext4
- kernel yjy #646 preempt 26. Nov 2013
- internal storage 4,0 GB
- device spoofed as Nexus 7
- multi-user
- ethernet support
- init.d support
- gameloft compatible
- USB-Hub enabled
- gamepad compatible (PS2, XBox, ...)
- kernel modules (cifs, tun, lan, serial, audio)
- latest hosts, su, su-binary, busybox
- Reboot Menue, Pimp my Rom, sEFix, FX Sound
- Dateimanager HD (Root)
- Nova Launcher
hints:
- use of CWM: wipe up/down to scroll – Power to execute – wipe right to go back
– Oma -
084.pngImage Enlarger
v1.0_01-6.pngImage Enlargerv1.0_03.jpgImage Enlargerv1.0_02.jpgImage Enlarger
hansfilz
Forum Posts: 19
2015/02/22 - 09:55
Thank you so much Oma. I will try tomorrow and let you know...
Hugo
56 Guest(s)
Devices in use: Desktop (49), Phone (7)
