[ ROM ] Kiano Elegance Android 4.4.2 KitKat custom root firmware (2014/06/10)
kikimora
2014/07/24 - 16:10
Where is this going to end... I am loosing my faith in decent battery life.
Thank you for your reply, though.
jmiat1100
Thanks Received: 5
2014/08/19 - 23:58
hi OMA
are you going to get an update to this rom to version 4.4.4 of android?
Thanks Received: 1379
2014/08/20 - 15:49
Not really. If you'd like you can check-out the OmniRom 4.4.4 build.
andreyamd
2014/09/15 - 22:07
Dear OMA, please collect the firmware 4.2.2 for Kiano Fly 9,7 Quad
Your firmware Elegance by Oma KitKat build v1.0 on my plate is loaded, just does not work touch screen and keys.
In advance I thank Andrew.
4.2.2 firmware from here Kiano Fly 9,7 Quad https://db.tt/GhaR03Wz
Grenade
2014/09/17 - 14:58
First thanks you, because i almost solve my trouble with the Kiano Elegance Android 4.4.2 KitKat. However, as i am new user with Android device, i would like to find a solution for my bad gyroscope behaviour. As it was said i should try to install a model fix  via cwm. The problem for me  is that i don't know how to do this, how to install this fix via cwm. So please, is there someone can describe  how must i do.
Thanks you and excuse my poor english
Grenade
2014/09/17 - 22:12
Hello
i come back again looking for help. I tryed to apply the fix ( Oma_RK31_KK_4.4.2_Elegance_v1.0_model fix_Cube_U30GT2) but it doesn't work the end of message is :
E: footer is wrong
E: signature verification failed
Installation aborted
Please could someone help me ?
2014/09/18 - 17:48
Do not unzip the file. Save it to the external sdcard. Boot the tab into flash modus and execute install from sdcard.
Grenade
2014/09/20 - 22:00
Thank you for yor answer M.OMA, but i can't foinf a solution. First, i would describe again the trouble. I have installed you firmware (Kiano Elegance Android 4.4.2 KitKat) that is great. But the gyroscope have bad behavior. So i tryed to apply the fix (Oma_RK31_KK_4.4.2_Elegance_v1.0_model fix_Cube_U30GT2) but i have the error that i describe before. I save this fix on xternal sdcard (i don't unzip it) and Boot the tab into flash modus and execute install from sdcard. But it not work.
May-be i have download a wrong fix ? In this case could you show me the right fix ?
Thank again for your help.
2014/09/21 - 14:24
Hm, which tab do you have and which kernel do you use?
Grenade
2014/09/21 - 16:44
Hello OMA
My tab is "cube U30GT2" but mais i bought it may-be it' another model tab. How to Know ?
the kernel is " 3.0.36+   tangy@tchipserver2 #95   Sun May 4  15:50:58 CST 2014
THANKS
2014/09/21 - 17:41
The download archive is corrupted.
Grenade
2014/09/21 - 18:12
¨Please a question again for you OMA, how to do to apply the KERNEL you have indicate ? and what do you mean when you wrote "incl. eraseIDB." ?
2014/09/21 - 18:20
Download the flash-pack from post#1. There is an instructions.txt included.
Replace the kernel in the folder rockdev/Images of the pack. EraseIDB will wipe the partition-layout of the NAND.
Grenade
2014/09/21 - 19:06
That's exactly what i did, but still have the gyroscope trouble.
Now i think i can't solve my problem,so i let down, what's a pitty.
Thanks you very much for all
Currently Online: GUCHEZ MICHEL
88 Guest(s)
Devices in use: Desktop (82), Phone (7)
behzad
84000
Kemoty
wagle
etan
KuPuK
