This is a generation 2 loader KK build for high-resolution tabs and RK903 wifi
Elegance by Oma KitKat build v1.0
– system ext4
– selinux kernel yf #49 preempt 22.05.2014
– internal storage 4 GB
– ethernet support
– init.d support
– gameloft compatible
– USB-Hub enabled
– Dateimanager HD (Root)
– Nova Launcher
Gen2 loader firmware will frequently generate trouble for the user. So, please read
the instructions carefully to understand how to change between gen1 (v1.24 loader)
and gen2 (v2.10 loader) firmware.
hints:
– to improve UI feeling disable animation scales in developer options
– to disable su notifications change notification in su app
– to prettify the build use Xposed Framework > Starterpack
Thanks to gebe14 😉
– Oma -
Wintermute, tomtom12, EzerchE, bizz, cio, OuTchOrNPer aspera ad astra, we rock the Tablets !
2013/07/09
2013/09/05
Yes, loader (v2.10) is the same one as in Kasty KK ROMs. I didn't need to touch loader in order to transition from Kasty to this ROM.
However, I forgot to replace kernel with suitable one (Kasty/DarthJabba U30GT2) during the flashing procedure which resulted in tablet being unable to boot up afterwards. Perhaps it was actually booting as USB device kept being reported in Windows as connecting/disconnecting but the screen stayed black/off. Luckily it was possible to switch tablet into flashing mode again and finally flash suitable kernel.
For what reason?
2013/11/18
i've just installed your rom on my Cube U30GT2 with the stock kernel and the CWM Fix from here.
No problems found, this ist the BEST rom i've had on this tablet until now.
Adblocker, SEFix, Resolution Changer, FileManager, CPU Tweaks, ... everithing is included.
Also the audio enhancement with Viper4AndroidFX is really helpful.
Do you plan to support the U30GT2 with future verisions?
MANY thanks for this great rom!
Best regards,
Thomas
PS:
I will cross post this to android-hilfe.de if it is ok for you.
Thank you for feedback!
Yes, the Cube is on our list to roll-out OmniRom and CM11.
Sure, you can post this on AH.
jmiat1100Per aspera ad astra, we rock the Tablets !
2013/07/25
Thanks for this great rom!
i am already using it on my Cube U30GT2 but its a bit runs slowly for me. Can i use theese overclocked kernels with this rom?
2013/09/05
@EzerchE: i guess you can, but better use newer OC kernels posted by DarthJabba here:
I use the top clocked one and it runs fine on my unit.
The following users say thank you to Wintermute for this useful post:
EzerchE
2013/09/05
If your tablet, by chance is Cube U30GT2, you may want to look at this:
cio
2013/04/04
cio said
I tried those kernels but gyroscope behaves bad, my screen always turns the wrong side, any advice?
update: The model fix also rotates 90º the screen, so applying first
Model fix (install via CWM): http://crewrktablets.arctablet.com/?wpfb_dl=1823
and then a custom kernel: kernel-95kitkat_cpu1800_gpu768h_ddr667, tablet works flawlessly!
59 Guest(s)
Devices in use: Desktop (51), Phone (8)
