[ ROM ] Kata FishTab 3 Android 4.2.2 custom root firmware (2014/07/02)
zypper3
46
2014/12/10 - 08:00
So smooth in my tablet except Injustice:Gods among us. Google play store says "Not Compatible to your device". Cant dwnload  the game Injustice
TedL
47
2015/01/12 - 20:20
Thank you for the Rom Oma! It works well with my dad's tablet after it refused to start on stock firmware. I've also flashed gapps because Google+ didn't work. Now I'm unable to use Hangouts, which I installed from the Playstore. I'm at a loss on how to make it work. The error when signing in to Google Hangouts is "Couldn't sign in, possibly because there's a problem with Google account permissions."
I've already tried revoking the permissions and logging again, but the same error occurs. What would you advise?
48
2015/01/12 - 22:31
Hm, just guessing ....
Do a clean install incl. eraseIDB. Install this via File Manager: http://crewrktablets.arctablet.com/?wpfb_dl=1686 and let it update.
Captcamilion
49
2015/08/05 - 19:36
Thanks sir Oma for the rom,, but i can't install it to my KATA.. i think i hard brick it,, so what i did was short pins 8 and 9,, and try install the rom,, but still my tablet won't boot up.. help me sir Oma.. Cry
50
2015/08/07 - 20:08
This is a very old thread here. What is the tab exactly and which firmware was on it?
TedL
51
2015/08/07 - 22:30
52
2015/08/08 - 18:05
Ok, when this is your tab then the build from this thread should work.
What exactly has happend? Which Windows do you run?
jiyoohji
53
2015/09/15 - 11:56
sir Oma can you port omni rom on kata fishtab 3?
akpoyah
54
2015/11/27 - 07:33
Hi Oma... I have followed the attached instructions very well, didnt encountered any problems during flashing and format_NAND fix. then reboot.. but still.. i can only see the fish logo for an hour. done this method twice.
also done the ff. wipe cache, factory setting, low level format.. no errors on everything.
what could possibly be the solution for this?
-win 7 pro 64bit
-used the Oma_RK31_Kata_FishTab3_JB_4.2.2_v1.0 FILES
Thankyou
55
2015/11/29 - 06:54
What firmware/kernel was on the tab before?
akpoyah
56
2015/12/01 - 23:47
Hmm..that i dont know. It was handed to me by my friend with a stuck logo boot only. Is there a way i can know the firmware version with this state?
57
2015/12/02 - 21:52
No, everything what was on the tab is gone.
asurabp
58
2015/12/09 - 08:57
Hi there, is there any other custom rom other than this? like cm?
profeduards
59
2017/01/06 - 05:08
Successfully flashed my Kata Fishtab 3 using Master Oma's Chuwi v88 ROM using RKDevelopTool; done the setup after the Welcome screen with Oma's flash logo screen; transferred apps using CloneIt; and after that, my tablet suddenly powered off and refused to power on, as in - nothing. Plugged my charger, press Power Button - nothing.
Run RKDevelop Tool again 2 times, and both successfully done, but my tablet did not boot to CWM as before.
Now, it is dead and I have no idea what actually happened to it.
Any assistance will be greatly appreciated.
Thank you and more power !
UPDATE:  Tried connecting my tab to a customized power supply (from old computer) that I converted to use its 5 and 12 vdc outputs, and my tab woke up. Reflashed and it went back to life !
"What you sow, so shall you reap!"
profeduards
60
2017/01/06 - 06:49
You may try this link, choose which one you like, if it is okay for the Admins/Mods to post here. . .
http://www.rockchipfirmware.com/firmware-downloads?field_brand_tid=All&field_model_value=&page=1
67 Guest(s)
Devices in use: Desktop (63), Phone (4)
swan12
heftpflaster
