[ ROM ] Kata FishTab 3 Android 4.2.2 custom root firmware (2014/07/02)
aldz5
31
2014/11/25 - 20:15
It always in recovery mode (same in the picture) not in update mode and if I run the RKAndroidTool, it says No Found RKAndroid rock usb. It is also in upside down:(
 IMG_20141126_031308.jpgImage Enlarger
32
2014/11/25 - 20:41
Best is to use a PC with Win7. Do not use an usb3.0 port. Here is a Driver Assistant: http://crewrktablets.arctablet.com/?wpfb_dl=1187
De-install driver first, then install again.
To start the tab into flash-modus plug the charger in and hard power off (long press Power until you hear a sound on the PC). While holding Volume+ plug USB into your PC.
aldz5
33
2014/11/26 - 18:00
No device found for upgrading. I already uninstall and install driver.
 Untitled-1.pngImage Enlarger
zypper3
34
2014/11/27 - 09:22
First uninstall all usb driver in your computer,  install Sir OMA's usb driver. Verify installation (go to computer, manage device then you can see in there if it is properly installed). Just follow Sir Oma's guide and your tablet will work again as new. Thanks to sir Oma, My KATA works perfectly again.
aldz5
35
2014/11/27 - 15:17
THANK YOU VERY MUCH SIR OMA AND ZYPPER3. MY KATA TABFISH 3, IT WORKS NOW. :)))))))
36
2014/11/27 - 18:39
Fine.
istananana
37
2014/12/02 - 05:42
I got this error messege: Test device failed, Error: Run failed after clicking erasing IDB and clicking RUN, my tablet won't open again.
38
2014/12/02 - 16:18
Most likely the USB driver are not installed properly. See post #32.
istananana
39
2014/12/03 - 04:29
This is the error message I get and my tablet doesn't open anymore they said the tablet might be bricked any solutions for this sir? :(
Image Enlarger
40
2014/12/03 - 17:47
Could be just me but I see nothing ...
istananana
41
2014/12/06 - 01:41
the issue is now okay oma thanks to you.. right now my problem is when I play games multitouch works for about a minute and suddenly it doesnt why is it like that sir?
42
2014/12/06 - 10:41
Sounds like a hardware issue. Check functionality with a multi-touch test app from Play Store.
istananana
43
2014/12/07 - 12:09
Everything seems to be working fine on the multitouch app it has 5 multitouch functions but when I play a game there goes the bug.. And also when opening a HD game it automatically crashes does it have something to do with the device itself?
44
2014/12/07 - 12:16
Could be. Leave a link here to the game so that other owner of the tab could test and report back.
istananana
45
2014/12/07 - 12:36
I tried downloading Injustice: Gods Among Us the game opens but after the Lex Luthor quote it closes the game and also I tried Dead Trigger 2 it crashes right away after I open it. And the multitouch game I tried is Shadow Fight 2 and Thor: TDW - The Official Game multitouch works for about a minute and after that it starts malfunctioning..
64 Guest(s)
Devices in use: Desktop (59), Phone (5)
swan12
heftpflaster
