[ ROM ] Kata FishTab 3 Android 4.2.2 custom root firmware (2014/07/02)
2014/10/25 - 08:39
Your stock firmware is on 240 dpi, so I used this.
Is the gps module running? Let me see the output from lsmod.
Lainrad
2014/10/25 - 11:15
Seems to be running(mtk_stp_gps 37350 0 - Live 0x00000000), though it doesn't find any satellites - that's for sure.
cdc_acm 13266 0 - Live 0x00000000
ftdi_sio 29129 0 - Live 0x00000000
pl2303 10561 0 - Live 0x00000000
cp210x 11073 0 - Live 0x00000000
snd_usb_audio 75637 0 - Live 0x00000000
snd_usbmidi_lib 15884 1 snd_usb_audio, Live 0x00000000
snd_rawmidi 15636 1 snd_usbmidi_lib, Live 0x00000000
snd_hwdep 4944 1 snd_usb_audio, Live 0x00000000
md4 3319 0 - Live 0x00000000
cifs 245765 0 - Live 0x00000000
rtl8150 8447 0 - Live 0x00000000
mcs7830 5049 0 - Live 0x00000000
dm9601 5600 0 - Live 0x00000000
tcp_veno 1409 4 - Live 0x00000000
tun 13050 0 - Live 0x00000000
isofs 30335 0 - Live 0x00000000
udf 69910 0 - Live 0x00000000
sr_mod 12988 0 - Live 0x00000000
sg 20434 0 - Live 0x00000000
cdrom 33656 1 sr_mod, Live 0x00000000
cuse 4129 0 - Live 0x00000000
crc_itu_t 1059 1 udf, Live 0x00000000
hubenable 565 0 [permanent], Live 0x00000000
wlan_mt6620 339130 0 - Live 0x00000000
vpu_service 11909 0 - Live 0x00000000
mtk_wmt_wifi 2482 0 - Live 0x00000000
mtk_fm_drv 154228 0 - Live 0x00000000
mtk_stp_bt 40370 0 - Live 0x00000000
mtk_stp_uart 22368 1 - Live 0x00000000
mtk_stp_wmt 400192 7 wlan_mt6620,mtk_wmt_wifi,mtk_fm_drv,mtk_stp_bt,mtk_stp
mtk_stp_uart, Live 0x00000000
mtk_hif_sdio 50214 2 wlan_mt6620,mtk_stp_wmt, Live 0x00000000
rk29_ipp 9957 0 - Live 0x00000000 (C)
mali 112485 5 - Live 0x00000000
ump 27320 11 mali, Live 0x00000000
rk30xxnand_ko 355048 0 - Live 0x00000000
2014/10/25 - 11:31
There is also a gps.ko in the build. Try to load it manually:
insmod /system/lib/modules/gps.ko
Lainrad
2014/10/25 - 11:50
insmod: init_module '/system/lib/modules/gps.ko' failed (File exists)
lsmod's still the same:
tcp_veno 1409 5 - Live 0x00000000
mtk_stp_wmt 400192 7 wlan_mt6620,mtk_wmt_wifi,mtk_fm_drv,mtk_stp_bt,mtk_stp_gps,mtk_stp_uart, Live 0x00000000
ump 27320 13 mali, Live 0x00000000
2014/10/25 - 14:36
Did you enable your location in settings?
Pls check with this app: https://play.google.com/store/apps/details?id=com.androits.gps.test.free&hl=de
bankei357
2014/10/25 - 19:20
hello sir oma im currently using your custom firmware for kata fishtab 3 and its been awesome my tab is running in Grade A.. you've recently released numerous kitkat versions for other rk3188 tabs, i was wondering if kata fishtab 3 can also have a kitkat custom firmware? tnx in advance sir.
Lainrad
2014/10/25 - 21:22
Yup, I did and I use exactly this one test.Sorry, it seems to be working. Maybe, it's the chip to blame, I had to spend several minutes in the open air for it to get a satellite, where my phone easily gets 15. Needs further testing, I'll report the result.
Totally working, just took damn long to start. Thanks a lot.
Lainrad
2014/10/28 - 10:49
Yup, maybe some universal fix for V88 KK version, based on this firmware?
2014/10/28 - 16:41
Fine. I guess the tab and the phone are not in the same price-class.
2014/10/28 - 16:49
Thank you for feedback!
Unfortunately we do not have KitKat sources for the  MTK 6620 wifi chip. Also this hardware solution is far away from mainstream, so that we will most likely not see a build which can be adapted. Furthermore a KitKat build needs a selinux kernel, which is not available for the tab.
The KK builds are anyway not such a big progress ... so, enjoy the JB build.
kenmacni
2014/11/13 - 10:17
Hi how can downlpad this firware ? To flash my kata fishtab3 tnx for ur answer guys
2014/11/13 - 10:54
See post #1.
zypper3
2014/11/20 - 09:47
Sir OMA, is there by a chance kata fishtab will experience Lollipop version like the other RK3188 tablets. Thanks a lot
aldz5
2014/11/25 - 08:48
Can someone help me to install this rom on my kata fishtab 3? my tablet is not opening and it always says when I am trying to wipe data/factory reset it always said No app2sd partition found. Skipping format of /sd-ext. Can someone help me to fix the tablet? I am trying to connect it to pc but nothing happened. Is there any way to fix this? it's CWM-based Recovery Chuwi V88 by Oma v6.0.3.1.
2014/11/25 - 19:38
Do a clean install incl. eraseIDB.
67 Guest(s)
Devices in use: Desktop (57), Phone (10)
swan12
heftpflaster
