Gents,
this is a Jelly Bean build for MT6620 wifi
T3 by Oma build v1.0 & format_NAND
– CWM 6.0.3.1 recovery
– system ext4
– kernel cheng #201 preempt 10.10.2013
– unified internal storage
– device spoofed as Nexus 7
– Multi-User
– ethernet support
– init.d support
– gameloft compatible
– USB-Hub enabled
– Dateimanager HD (Root)
– Nova Launcher
Instructions are included in the download pack.
A few hints:
– higher performance > disable all animation scales in developer options
– don't show su notifications > disable in Superuser
– to prettify the build use Xposed Framework > JB Starter Pack
– Oma -
admin, davedcmp, kustorrotor, zypper3, TedL, Captcamilion, profeduardsPer aspera ad astra, we rock the Tablets !
DNS Airtab P70QW 2nd gen has also MT6620 wifi
Kernel: http://crewrktablets.arctablet.com/?wpfb_dl=1939
2014/05/04
Greetings sir OMA.. I managed to install your custom firmware for my Kata fish tab 3.. it booted and I was able to use it for a little while.. WiFi is not working sir.. after I rebooted it suddenly stucked on boot logo.. what supposed to be the problem sir? Is it the kernel? Should I use the other kernel for T3 you posted along with the custom firmware.. tnx very much sir..
Try again incl. eraseIDB.
No, use only kernel for your specific tab.
Kernel is for Airtab user to use the build on their tab.
Install this via CWM: http://crewrktablets.arctablet.com/?wpfb_dl=728
You need to do a factory reset directly after installing this fix.
2014/10/06
Sir Oma, i am using your custom rom do i have to flash the ""Format NAND'' or this one ''Install this via CWM: http://crewrktablets.arctablet.com/?wpfb_dl=728'' for this concern ”swap external to internal storage for Kata fish tab3. thanks
No, no need for the fiormat_NAND. Just do as descriped in post #10.
2014/10/19
Hi, found this topic while searching for an alternative firmware for my DNS AirTab p100qw, while I'm trying to turn on the wifi on KK(this rom, I suppose, may also help me with it).
This rom, magically, works But there is one minor/major problem I have with this one: the screen is upside-down, the acceleromrter(and screen rotation along with it) doesn't work (touchscreen also didn't, I had to copy cm10.1 config fix files through root explorer, cause CWM patching, though happily claiming that all's done, copied nothing). Also, CWM doen't see the internal memory.
Please, help me, Oma, if possible.
Edit: Sorry, my bad, ft5x0x config and CrewRKTablets_RK31_CM10.1_sensor_x=-y_y=x_z=z seems to do the trick, but, again, with manual deploying only, could you, please, do something about CWM?
Also, I fund out that GPS isn't working(probly, because Fish Tab 3 has no GPS), is it fixable?
Pls test: http://crewrktablets.arctablet.com/?wpfb_dl=2201
2014/10/19
Pls test: http://crewrktablets.arctablet.com/?wpfb_dl=2201- Oma -
Thank you, it's a nice full fix for accel and too small an interface, but sadly it doesn't do well with GPS, or, maybe, the full patch does, but all I could do is to copy the files into system manually, since CWM patching simply doesn't work.
79 Guest(s)
Devices in use: Desktop (73), Phone (6)
hans41
rickybk
soniya07
ironmangitar
