Gents,
This is a build for Chuwi V17HD which runs also on the Cube U25GTC4Â
Oma KitKat build v3.3  - change kernel weng #338 in folder rockdev/Images before flash
– system ext4
– selinux kernel weng #17, weng #554 [v3.3]
– internal storage 2,0 GB
– device spoofed as Nexus 7
– ethernet support
– init.d support
– gameloft compatible
– USB-Hub enabled
– Dateimanager HD (Root)
– Nova Launcher
hints:
– higher performance > disable all animation scales in developer options
– don't show su notifications > disable in Superuser
- to start the tab into flash-modus boot the tab and press Switch in RKAndroidTool or hold Power and Reset until "Found …" is shown.
- use of CWM: wipe up/down to scroll – Power to execute – wipe right to go back
This is a gen2 loader firmware.
– Oma -
No. Complete other hardware.
2014/05/27
Sorry for double of question from http://www.arctablet.com/blog/forum/crewrktablets-rk3188-entwicklung-customroms-development-croms/rom-chuwi-v17hd-android-4-4-2-kitkat-custom-root-firmware-20140402/ . I'm not sure where should it placed to. So placed to both themes about this firmware. Will try to delete one of them if it will be needed.
Hello, Oma
having cube u25gt-c4, as you wrote it is compatible with this tablet.
Flashed your 3.2 firmware. Now have one bad thing with tablet – if I press the button on it to switch off the screen then I cannot switch it on – only reset. If it starts to sleep on the timer – the same problem.
flashed kernel from 3.1 – button is ok, but 3 cm on the right side of touch is not working.
returned to kernel 3.2 – touch is ok, button isn't.
All worked well on the factory firmware. So hardware should be ok. But I don't have the original firmware now. On the cube site they dont have firmware for C4, only for other model U25GT.
Only thing I could do wrong – as I think. _Maybe_, I didn't untick loader, when flashed CWM, I'm not sure.
Have you any suggestions for me?
Cube seems not to be so lucky with the hardware. Build in post one is based on stock v1.03 and kernel weng #17. Meanwhile I see stock v1.08 with kernel weng #338.
Here are the kernel:
V17HD - hlq #396 - http://crewrktablets.arctablet.com/?wpfb_dl=1718
U25GTC4 weng #17 - http://crewrktablets.arctablet.com/?wpfb_dl=1771
U25GTC4 weng #338 - http://crewrktablets.arctablet.com/?wpfb_dl=1772
For me the hlq #396 works best. Check it out. You can flash the kernel separately, just tick parameter and kernel.
Anyway, here is the latest stock v1.08: http://www.51cube.com/ch/DownShow.asp?ID=243
tommyx274Per aspera ad astra, we rock the Tablets !
2014/05/27
Big thanks, Oma.
What I have now.
396 - problem with right side of touch (3 cm of touch on the right side isn't working)
017 - problem with button (cannot switch on after swithing off)
338 - weird effect on the screen and doesn't boot (maybe some loader incompatibles?)
flashed all kernels on your 3.2 firmware with parameters from 3.2
Shall now try stock (great thanks for link - I'm not so common with chiniese sites ;). Will hope stock will be working at last on this tablet. I'm not very lucky with your firmware as I see. I'm only wanted clean firmware with root and CWM.
Chiniese server is _very_ slow, so shall write later what I will have with stock.
2014/05/27
So, what I have at last.
Chinese stock 1.08 work ok.
But I checked your firmwares on Cube once more - all works as in my previous comment with the same bugs.
tried to apply your firmware with unchecking kernel - all works almost ok (touch ok, button ok), but orientation swapped - when needed vertical it switched into horisontal and contraverse.
So returned to stock. I've found root for it, got Oma's CWM for it, but didn't got _big_ system partition (still 512 Mb). Thats a pity. But it works now, so adventures are over maybe.
Oma, big thanks to you for help once more.
2014/10/17
U25GT2-T should be a RK3026 - http://www.arctablet.com/blog/forum/crewrktablets-rk3026-entwicklung-und-customroms-development-and-croms/rom-cube-u25gt2-t-android-4-4-2-kitkat-custom-root-firmware-20140406/- Oma -
wow 1000 thanks Oma.
just one thing should i flash the 2 version or just most recent ??Â
Can you pls verify the CPU first? Post a screenshot: https://play.google.com/store/apps/details?id=com.arctablet.cpucheck
2014/10/17
Can you pls verify the CPU first? Post a screenshot: https://play.google.com/store/apps/details?id=com.arctablet.cpucheck- Oma -
 pls!!
Ok, RK3026. Just flash the latest build v1.1.
2014/10/17
thanks a lot!!Â
70 Guest(s)
Devices in use: Desktop (58), Phone (12)
lbalexa001
rkg2303
sergey-tax
houseofcandy
duviauxi
benevento89
