[ ROM ] Chuwi V99X Android 4.2.2 custom root firmware (2014/06/20)
fadilimurati
2015/11/28 - 17:42
Gents,
this is a generation 2 loader Jelly Bean build for Chuwi V99X S/N 1401;-)
For tabs with S/N 1312 pls change this kernel in folder rockdev/Images.
For tabs with S/N 1311 pls change this kernel in folder rockdev/Images.
cRom v1.0
– stock 4.2.31 recovery, CWM 6.0.3.1 recovery
– system ext4
kernel bob #688 preempt 13.01.2014
– internal storage 4 GB
– Multi-User
– ethernet support
– init.d support
– gameloft compatible
– USB-Hub enabled
– Dateimanager HD (Root)
– Nova Launcher
Instructions are included in the download pack.
A few hints:
– higher performance > disable animation scales in developer options
– don't show su notifications > disable in Superuser
– to prettify the build use Xposed Framework > JB Starter Pack
– Oma -
Gents,
cRom v1.0
– system ext4
– Multi-User
– ethernet support
– init.d support
– USB-Hub enabled
– Nova Launcher
A few hints:
– Oma -
Can we just put wi-fi driver to this firmware i think it works well on my tablet.
is there any way to modify that firmware or I need just to keep trying.
Thank you very much for time you spend to reply me.
fadilimurati
2015/11/28 - 22:50
fadilimurati said
Wrong kernel. Did you change it?
Yes i changed it but it just vibrates after all process is done
fadilimurati said
ohhh I meant loader  not kernel
2015/11/29 - 06:52
You need to change the V99X kernel in folder /rockdev/Image. Flash again.
Currently Online: hoholms
48 Guest(s)
Devices in use: Desktop (42), Phone (7)
hoholms
rammaiden
iongeorge411@gmail.com
legrandhommer
mindra
xstouf
