2014/12/30
Dann teste mal das hier: http://crewrktablets.arctablet.com/?p=3319- Oma -
dein Lob findest du im richtigen thread
2015/03/03
Gents,KTU84P (Android 4.4.4) has landed on Chuwi V88
- gen1 loader
- selinux off
- stock 4.2.01 recovery, CWM 6.0.3.1 recovery
- system ext4
- kernel bob #397
- internal storage 4,0 GB
- Multi-User
- device spoofed as Nexus 7
- ethernet support
- init.d support
- gameloft compatible
- USB-Hub enabled
- gamepad compatible (PS2, XBox, ...)
- kernel modules (cifs, tun, lan, serial, audio)
- latest hosts, su, su-binary, busybox
- Reboot Menue, sEFix, FX Sound
- Dateimanager HD (Root)
- Nova LauncherFlash instructions are included in the download pack.
If you are on a gen2 loader firmware (KK stock or v3.x build), please read
the instructions carefully to understand how to change between gen2 (v2.1x loader)
and gen1 (v1.24 loader) firmware and vice versa.Build works as is for 1st gen V88, V88S, V88 TIG and
V88 1st gen clones (or use tab specific kernel, see archive):
- ICOO Fatty2
- Dragon Touch R8 mini
- Alcor Zest Q813i
- Alcor Zest Q813ix
- Cbox Tab X785
- Ritmix RMD-785
- Dyno 7.85
- Xtreme X81Kernel for 2nd gen V88/V88S & V88HD (change in rockdev/Images before flash):
V88/V88S: kernel bob #419
V88HD: kernel bob #610hints:
....use Nova launcher and set animation/scroll to "faster than light" and
....enable Entropy Fixer with value 256
– to prettify the build use Xposed Framework > Starter PackBe aware: it is your own risk!
Dear Oma,
I have to mention that SELinux isn't enabled by default (getenforce returns with: Disabled.)
Is there a way to manually enable it?
Sincerely,
Hiero
That's what is says: selinux off.
2015/04/18
Hi Oma, thank you for good ROM.
After i install V.2.4, V.3.0 and V.3.2. It's ok. but
When I pair bluetooth with new gift "MI Band" App : MI Fit and Setting > Bluetooth can not pair device.
So I need to know chuwi v88 with new ROM that can pair with bluetooth 4.0 (BLE)? If it's ok that how to pair chuwi with MI Band.
Thank you.
42 Guest(s)
Devices in use: Desktop (34), Phone (8)
wogoko8553@yubua.com
hellander
elousstad
relaytester
revoltown
