[ ROM ] Chuwi V88 4.4.4 custom root firmware (2014/08/05)
2014/08/06 - 20:09
Gents,
KTU84P (Android 4.4.4) has landed on Chuwi V88
V88 by Oma KitKat build v2.4
- gen1 loader
- selinux off
- stock 4.2.01 recovery, CWM 6.0.3.1 recovery
- system ext4
- kernel bob #397
- internal storage 4,0 GB
- Multi-User
- device spoofed as Nexus 7
- ethernet support
- init.d support
- gameloft compatible
- USB-Hub enabled
- gamepad compatible (PS2, XBox, ...)
- kernel modules (cifs, tun, lan, serial, audio)
- latest hosts, su, su-binary, busybox
- Reboot Menue, sEFix, FX Sound
- Dateimanager HD (Root)
- Nova Launcher
If you are on a gen2 loader firmware (KK stock or v3.x build), please read
the instructions carefully to understand how to change between gen2 (v2.1x loader)
and gen1 (v1.24 loader) firmware and vice versa.
Build works as is for 1st gen V88, V88S, V88 TIG and
V88 1st gen clones
(or use tab specific kernel, see archive):
- ICOO Fatty2
- Dragon Touch R8 mini
- Alcor Zest Q813i
- Alcor Zest Q813ix
- Cbox Tab X785
- Ritmix RMD-785
- Dyno 7.85
- Xtreme X81
Kernel for 2nd gen V88/V88S & V88HD (change in rockdev/Images before flash):
V88/V88S: kernel bob #419
V88HD: kernel bob #610
hints:
....use Nova launcher and set animation/scroll to "faster than light" and
....enable Entropy Fixer with value 256
084-1.pngImage Enlargerv2.4_06a.pngImage Enlargerv2.4_09.jpgImage Enlargerv2.4_03.jpgImage Enlargerv2.4_02.jpgImage Enlargerv2.4_08.pngImage Enlargerv2.4_04.pngImage Enlargerv2.4_01.jpgImage Enlargerv2.4_05d.pngImage Enlargerv2.4_07.pngImage Enlarger
evo666, cscrive
priester100
2014/08/07 - 15:59
kann man sowas nicht auch für das archos platinium 97 hd machen zur zeit läuft bei mir das onda 978 4.4.2 kernel 3.3.0 währe echt super
2014/08/09 - 22:28
Schau mal hier, da ist was für dein Tab dabei: http://crewrktablets.arctablet.com/?p=2982
priester100
jastaz23
Forum Posts: 28
2014/08/11 - 15:58
Hi sir Oma, I've flashed this rom on my Pipo U8 and it boots fine, I followed the instructions I read on switching from Gen2 loader back to Gen1, after that what I did is I used a JellyBean kernel from my previously used rom and a Stock JellyBean recovery to format data/cache at first boot since CWM is not working for Pipo U8 as U8 doesn't have Volume Buttons, after it boots to to Homescreen I flashed a generic TWRP (1024x600 reso) for JellyBean and touch on twrp works fine,That UI on this is really fast and smooth, It was a smooth install and a smooth rom until I experience some bugs…
Now here's the problem…
-Wifi doesn't work
-Camera view finder is Inverted (viewfinder only not the camera UI)
-Bluetooth doesn't work
-MP3 doesn't play
I tried rebooting a few times but it still doesn't work :(
that is all the bugs and issues I can find, I can't seem to make aiolog work on my pc, I dont know why, so I can't provide you a logcot or dmseg… Is it possible to do a dmseg log from terminal emulator?
Hopefully you can provide a fix for this if possible :) alot of U8 users from our group have been wanting this one too...
Thank you sir for all your hard work!
2014/08/11 - 16:40
Chuwi V88 build is for MTK 5931 wifi. Pipo U8 has RK903 wifi, which is not implemented.
Rock293031
Forum Posts: 39
2014/08/14 - 01:01
Hi Oma,
habe gerade die 4.4.4 2.4 auf meinem RK3066 getestet. Leider RK903 daher kein WIFI.
Die ROM ist sehr schnell.
Was auch immer Du gemacht hast, die ROM hat 2000 Punkte mehr als CM11 oder Omni.
Echt gut. Freue mich schon auf so eine ROM für das Iron.
Grüsse, Neptune
priester100
2014/08/14 - 07:39
Danke ja oma das ist eines so wie ich gelesen habe . aber jetzt habe ich das problem wie installiere ich es weil habe ja kein laut leiser taste so wie in txt drinsteht
2014/08/14 - 20:56
Die CWM unterstützt Touch ... vielleicht dein Kernel auch. Ansonsten per USB-Maus.
priester100
2014/08/15 - 12:57
sorry das geht nicht cwm drauf kann man nicht die rom als image  machen währe echt super weil rockchip nimmt er nicht an aber phoenixsuite
evo666
2014/09/10 - 13:04
Hi OMA, thanks for the great build!
I just loaded this into my V88S without quad in sn and works great with kernel #459. This was the kernel that came with the tab. My question is should I be using this kernel or kernel bob #419? Also is there any limitation to use stock kernel?  Thanks again!
Here is a photo.
Image Enlarger
2014/09/18 - 18:24
When you hardware is stable with kernel #459 stay with it.
cscrive
2014/09/19 - 22:04
Hello
I've just bought a chuwi v88 but it was delivered with 4,2,2
I try to understand how to flash it to 4,4,4 but I'm a little bit lost with all these kernels, loaders, room versions...
My v88 is rooted and CWM 6,0,3,1 is installed
it's a CW V88 QUAD
4,2,2
kernel 3,0,36+
bob@bob-desktop#445
build rk30sdk-eng4,2,2JDQ39 eng.kevin20131123,163339tes-keys
Could you please confirm if this room is compatible with my actual system??
I thank you very much
2014/09/19 - 22:14
2nd generation ... look to the back: no QUAD in the serial-number.
Latest kernel is #419.
cscrive
2014/09/20 - 11:18
Thank you for your quick answer, but I'm really lost
Step by step:
- first or second generation? It is written on the back:
chuwi model CW0838
V88 16G2131200250
Pad mini
- kernel: bob@bob-desktop #445 3,0,36+
May I change it? and how to proceed??
- which version of your custon rom may I download with such a V88?
Thank you very much for your work and your help
2014/09/20 - 11:31
First gen has V88 QUAD 16G2 .... so your tab is 2nd gen. Latest kernel for your tab is #419.
Download the Pack from post#1 and decompress. Download kernel #419, decompress and replace in folder rockdev/Images. Flash acc. to instructions.txt.
68 Guest(s)
Devices in use: Desktop (61), Phone (7)
