[ ROM ] Chuwi V88 4.4.2 custom root firmware (2014/08/03)
2014/08/05 - 18:25
Gents,
Small update of the KitKat Stock Edition
Changelog:
- gen2 loader v2.16
- selinux kernel bob #153 (works for gen1 and gen2 V88/V88S)
- selinux kernel bob #109 (for V88HD, change in folder rockdev/Images before flash)
- additional Play-Store fixes
- fixed gapps provider
- updated gapps
- updated su
- native init.d support
- optimized dalvik libs (optional, flash via CWM)
V88 by Oma KitKat build v3.2
- stock 4.4.0 recovery, CWM 6.0.3.1 recovery
- system ext4
- selinux kernel #153
- internal storage 4,0 GB
- ethernet support
- init.d support
- gameloft compatible
- USB-Hub enabled
- gamepad compatible (PS2, XBox, ...)
- kernel modules (cifs, tun, lan, serial, audio)
- latest hosts, su, su-binary, busybox
- Reboot Menue, sEFix, FX Sound
- Dateimanager HD (Root)
- Nova Launcher, Google Now Launcher
hints:
....use Nova launcher and set animation/scroll to "faster than light" and
....enable Entropy Fixer with value 256
Gen2 loader firmware will frequently generate trouble for the user. So, please read
the instructions carefully to understand how to change between gen1 (v1.24 loader)
and gen2 (v2.16 loader) firmware and vice versa.
084.pngImage Enlargerv3.2_01a.pngImage Enlargerv3.2_04.jpgImage Enlargerv3.2_02.jpgImage Enlargerv3.2_03.jpgImage Enlargerv3.2_06.jpgImage Enlargerv3.2_07b.jpgImage Enlarger
rexf
Forum Posts: 19
2014/08/10 - 09:45
My V88HD appears to be bricked after loading the 2.16 Loader.  It loaded successfully, but the Devtool status showed "No Found Any Devices".  Now it does not show any response, even if I just plug in the power.
Any advice?
Thanks,
Wayne
2014/08/10 - 11:40
Start the tab into flash-modus by holding Reset and plug usb-cable in.
rexf
Forum Posts: 19
2014/08/12 - 17:40
Hi Oma,
Thanks for the reply.  Yes, I tried that.  It doesn't respond.
Any other ideas?
Thanks,
Wayne
2014/08/12 - 20:16
Hm, this indicates you flashed the wrong kernel into the tab.
Try to start the tab into mask-rom modus:
rexf
Forum Posts: 19
2014/08/13 - 20:33
Thanks Oma.  I'll give that a try - a weekend job I think!
I didn't install the kernel, only the bootloader (2.16).  So, it might be worth asking if other people have managed to put bootloader 2.16 on a V88HD OK.  Otherwise, there may be a problem.  Or I just got unlucky?
Regards,
Wayne
2014/08/14 - 21:56
Ok, you only flashed the loader. In which running build?
57 Guest(s)
Devices in use: Desktop (55), Phone (2)
