[ ROM ] Chuwi V17HD 3rd generation Android 4.4.2 KitKat custom root firmware (2014/12/23)
This is for the model with volume rockers and S/N starting from Q8G1141100214.
Thanks Received: 1385
121
2015/02/17 - 18:28
Yes, leave everything as is. On which windows are you?
Timo123
122
2015/02/17 - 18:39
I have windows vista 32 bit.
123
2015/02/17 - 18:49
Hm, I don't think the Assistant includes the Vista drivers any longer.
Pls find attached the Vista driver and a similar Instructions paper for manually installation.
Timo123
124
2015/02/17 - 20:08
step 3 went fine but now when i try to do step 4 it says "msc device cant upgrade".
125
2015/02/17 - 20:15
You are in Android now?
Timo123
126
2015/02/17 - 20:40
I did step 3 and my tablet booted in german android. But now when i try to do step 4 in my computer it says that " msc device cant upgrade"
127
2015/02/17 - 20:44
You can change the language in settings/language (Einstellungen/Sprache & Eingabe).
Use the included app RebootMenue and choose reboot to bootloader.
Timo123
128
2015/02/17 - 21:22
Than you very much Oma. Now everything works fine and i have google play. Without you this tablet is useless. Thank you.
mezarie
129
2015/02/21 - 21:30
Just wanted to say THANK YOU.
You've just save my daughter tablet.....
Thank you again
Chuwi V17HD Q8G1141100894
130
2015/02/21 - 21:36
Great! Thank you for registering to let us know!
mezarie
131
2015/02/21 - 21:55
I've got a problem now it ask me à code in german language and i've not specify one what is this code ?
Please help !
132
2015/02/21 - 21:58
What code?
Change language in settings/language (Einstellungen/Sprache&Eingabe).
mezarie
133
2015/02/21 - 22:02
I have a code when i've restar the tablet :
Passwort zum Entsclusseln des speichers eingeben
Passwort eingeben :
This exactly what it appears on my screen
134
2015/02/21 - 22:04
There went something wrong with the flash process. Flash again incl. eraseIDB.
mezarie
135
2015/02/21 - 22:26
Ok I'm french and perhaps i've made something wrong.
Then i'll listing my step
My chuwy had a  black screen after my daughter play whith
Then i've download Oma_RK31_Chuwi_V17HD_3rdgen_KK_4.4.2_v1.0
1 Driver for my tablet : ok
2 start the tab into flash-modus ( can't choose anything) but the tablet was found
a) run RKAndroidTool.exe with admin rights
b) hold power button and reset until "Found ..." is shown  : OK
3) flash the firmware with RKAndroidTool
a) do not untick the loader
b) Run
c) stock recovery will format the NAND
d) wait 4 min
ok
4) flash the CWM recovery with RKAndroidTool
a) tick CWM
b) untick kernel, boot, recovery, system
c) Run
d) tab boots into CWM
e) reboot system now (both answers are No)
Impossible to make that impossible : to upgrade
Currently Online: dfrt
69 Guest(s)
Devices in use: Desktop (60), Phone (10)
dfrt
PQNY
chema1971
speedyftp
georgicaa97
kkn
