Unbelievable ... next tab with 2nd gen hardware and 3rd gen serial-number. Pls use the build from the 2nd gen thread.
druh09Per aspera ad astra, we rock the Tablets !
2015/01/10
Hi GuysÂ
I must say more once thank you for nice room my chuwi works perfect and google play works amazing. With stock rom we dont have google play at all:
I have one question, i bought http://www.geekbuying.com/item/XiaoMi-10400mAh-USB-Portable-Power-Bank-External-Battery-Charger-for-Mobile-Phones-Tablets-iPhone-Samsung-HTC-Google-325638.htmlÂ
Powerbank from geekbuying and then i release that it can't charge my chuwi because it is charging with dc power not usb Â
Is there any way to buy some converter dc to usb or something simillar that can allow charging Â
Thanks a lot , Reuf
Hello Reuf,
It's probably doable to use a dedicated USB cable with a power connector matching the tablet if your power charger is 5V else there is also the option of using a power booster but it's not very convenient.
What are you power charger specs (voltage and amps) ?
Cheers
2015/01/10
I'm using power bank from xiaomi 10400 mahÂ
From link i found out thisÂ
Battery Type | High quality Li-ion batteries |
Color | Silver |
Input Voltage | DC 5V |
Output Voltage | DC 5.1V |
Input Current | 2.0A(TYP) |
Output Current | 2.1A(TYP) |
Rated Capacity | 3.6V/10400mAh(TYP) |
Charging Time | About 5.5 hours (Use 5V/2A plug and the standard cable) |
About 5.5 hours (Use 5V/1A plug and the standard cable) | |
Product Dimensions | 90.5*77*21.6mm |
Load Testing | Automatically detect load insert and pull out |
Safety Protection | This product support input high voltage protection, input counter-attack protection, output over-current protection, output over-voltage protection, output short circuit protection, battery over-charge / over-discharge protection, battery cells PTC protection, charging/discharging temperature protection. |
Protection Recovery | Use charger for action, can be restored. |
Net Weight | 250g |
Charge Temperature | 0 ~ 45 degree centigrade (TYP) |
Discharge Temperature | Start the output temperature: -10~50 degree centigrade (TYP) |
Continuous output temperature: -20~60 degree centigrade (TYP) |
When asking for the power charger specs, I was referring to your tablet power charger (the one that plugs on the wall) not the power bankÂ
Based on the fact the power bank is able to deliver 5V (usual voltage for USB) and enough power (see output power rating in the power bank spec) there should be no problem to connect the powerbank directly to the the tablet power charging connector.Â
Such cables are not very frequent but they do exist and are quite cheap, look here for instance:Â http://www.dx.com/p/dc-2-5mm-plug-to-usb-charging-cable-for-tablet-pc-100cm-217276Â you just need to make sure the connector matches the size of the charging socket on the tablet side.
Cheers
What is the kernel (see settings/About the tab)?
2013/10/03
What is the kernel (see settings/About the tab)?- Oma -
I do not know because the tablet starts on a blank page, this is my daughter
EDIT: She just told me she had flashed the rom for 1st generation not so good rom that is why it will not start.
Sorry for my English, I'm French
Not sure at the moment because we have seen that serial numbers starting from Q8G1141200500 does have 2nd gen hardware again. So pls try the 2nd gen build: http://www.arctablet.com/blog/forum/crewrktablets-rk3188-entwicklung-customroms-development-croms/rom-chuwi-v17hd-2nd-generation-android-4-4-2-kitkat-custom-root-firmware-20140921/
Ok then try build from post#1.
105 Guest(s)
Devices in use: Desktop (87), Phone (17), Tablet (1)
3nf
lesfurets
lbalexa001
rkg2303
sergey-tax
houseofcandy
