[ ROM ] Chuwi V17HD 3rd generation Android 4.4.2 KitKat custom root firmware (2014/12/23)
This is for the model with volume rockers and S/N starting from Q8G1141100214.
Thanks Received: 1383
76
2015/01/14 - 06:31
Yes, 3rd gen.
yoshovon
77
2015/01/14 - 08:17
Hey Oma,
Firstly thanks a ton for your great works. I bought a chuwi v17hd  5 days ago. Serial no.: Q8G1141200107 and karnel is: #814 and it dosent have HDMI port but has volume keys in stead.
-- I want to avail google play (absent currently)
-- I want to avail usb charging (only chargeable with dc charger now)
 So is this 3rd gen rom is ok with my device? and can solve the issues stated above?
Thanks again..
78
2015/01/14 - 09:30
Yes, 3rd gen.
Build in post#1 includes fulls google apps support, incl. Play Store. USB-charging is kernel related.
yoshovon
JellyBean
79
2015/01/14 - 17:20
Yes, 3rd gen.
Is it possible to revert to stock (fully) from your customized ROM? The eraseIDB is possible to revert etc.?
I'm having the same type of problems as some other users here with my 3rd gen V17HD; basically no apps installed (and no Google Play store), not possible to add a Google account (constant error message), random "Unfortunately xxxxx has stopped" as well as random reboots and multiple intermittent bootscreen loops before actually booting the ROM, ghost characters when typing and simultaneously charging the battery, not possible to charge via USB etc. etc.
80
2015/01/14 - 17:22
Sure.
JellyBean
81
2015/01/14 - 18:10
Sure.
Any special procedure to go back to stock like the instructions for your ROM?
BTW, your ROM looks and feels awesome! Wink
yoshovon
82
2015/01/14 - 21:29
Oma, It worked like a charm for me. Thanks again. But USB charging is the only thing missing..Do you have other karnel that avail the usb charging? If so can i flash it separate?
Thanks again
83
2015/01/15 - 10:24
No other kernel available. Sorry.
werthercc
84
2015/01/18 - 12:59
I have CHUWI Model:CW0858 with s/n: Q8G11410000668
what generation is it?
Thanks in advance!
85
2015/01/18 - 14:12
HDMI port or volume rockers?
werthercc
86
2015/01/18 - 17:52
Oma, volume rockers.
87
2015/01/18 - 17:54
Gen2.
werthercc
druh09
88
2015/01/25 - 18:21
Could somebody tell me what the hell I'm doing wrong?
So i downloaded everything, did everything exactly like it said in the instructions but it just wont work, i always have to reflash the stock firmware from chuwi.
"     d) tab boots into CWM"
It just wont go there besides having NO failure messages. When i try to start my tablet it will just stay dark.
Is there any other way i can get a hold of that sweet sweet 2GB (or even more) internal storage?
8GB
No hdmi
Q8G1141201671 (am I trying to flash the wrong firmware here?)
89
2015/01/25 - 18:51
No, according to serial number it is 3rd gen. Did you execute eraseIDB?
Which stock firmware do you use?
- Om -
druh09
90
2015/01/27 - 18:13
This one right here and yes i did execute eraseIDB.
Currently Online: POELE
81 Guest(s)
Devices in use: Desktop (65), Phone (16), Tablet (1)
POELE
hststs44
lokeshreddymtpl
scoopsat
Mikewood
XSTR
