The serial-number is on the back.
3rd gen. Go on with build in post#1.
We have a lot of confusion with two undocumeted hardware revision of V17HD here.
My V17HD (1st gen) has a HDMI port and no volume rockers.
2nd gen (can be identified by volume rockers) has totally different hardware from 1st gen. So, that's why we see so many tabs crashes on the "strange" kernel.
3rd gen (can be identified by serial-number) has slightly different hardware from 2nd gen (main thing I see is touch controller). So, that's why a lot of user reports mirrored touch.
Unfortunately we see also a mixed population: 2nd gen hardware with 3rd gen serial-number. However, tab will not crash. So, we can correct that.
Win8 and the unsigned Rockchip USB flash-driver are not friends. Best is to use a win7 PC. Do not use USB3.0 ports.
Well, there are may be ways patching configs but I have already seen advanced users struggeling with. I do myself not use win8.
Same for all win versions when config files are corrupted by installation of other smartphone driver, etc.
In all that cases I strongly recommend to use another PC.
2015/01/10
First Oma thank you for this great firmware.
2nd i sorted problem in totally different way, i used windows 8 , i installed first drivers and all was ok but issue was that i mention above it automaticaly recognize my device i dont even need to go into boot mode or whatever you call it when you press power + reset. I just did this.
Connect device via usb and power adapter, then open android flashing tool from your zip file, after that i click on option SWITCH, and device automaticaly boot into that mode, then i just simple click run and wait until it is done. After that i repeat same thing for CWM and now i got all that i need.
Thanks again , Reuf
Fine.
3rd gen.
fmolinaPer aspera ad astra, we rock the Tablets !
Currently Online: portvein
94 Guest(s)
2 Guest(s)
Devices in use: Desktop (78), Phone (14), Tablet (3)
portvein
POELE
hststs44
lokeshreddymtpl
scoopsat
Mikewood
