[ ROM ] Chuwi V17HD 3rd generation Android 4.4.2 KitKat custom root firmware (2014/12/23)
This is for the model with volume rockers and S/N starting from Q8G1141100214.
petrikanus
46
2015/01/01 - 14:48
Flash the 2nd gen build, incl. eraseIDB.
Ok did that.
Had to boot again. Saw the "OMA" logo and then it crashed saying:
"Der Prozess "android.process.acore" wurde beendet.
When I click ok it seems to work just fine.
Don't quite understand why this works, because the serial number is higher so it should need 3rd generation.
Thanks for your help!Laugh
Thanks Received: 1383
47
2015/01/01 - 14:58
Fine.
My guess: 2nd gen hardware found somewhere mixed up with the new batch ... welcome to Chinese QM-System ;-)
snolly
48
2015/01/07 - 18:02
I followed your steps and flashed this.
After step 3 it boots into android (in German) and orientation is upside down (on both portrait and landscape) and touch is messed up (it will not respond to the region I am tapping).
I ignored that and did step 4 which got me into CWM. After I rebooted it still gets into that messed up German android that I can not use as it will not respond to the touching.
I then did EraseIDB and redid all steps with the same results.
Edit: I also flashed the other kernel, nothing changed.
Any ideas? What did I do wrong?
49
2015/01/07 - 19:26
Curious, according to your post in the other thread the tab was running kernel #814.
You can change the language in settings/language (Einstellungen/Sprache).
snolly
50
2015/01/08 - 13:54
Oma FYI tablet with serial Q8G1141200537 flashed succesfully with revision 2 ROM. Revision 3 did not work.
51
2015/01/08 - 18:04
Ok, this was now the second tab with 3rd gen S/N coming with 2nd gen hardware.
creon
52
2015/01/08 - 23:11
A quick update..
I flashed the 3rd gen rom and all went ok. My s/n is Q8G1141200085.
This is the 2nd v17hd i get, 1st one i bought it late november from geekbuying had play store and all was working ok so i didnt bother with custom roms (gave it as a gift), this one however had crapy factory rom with no play store installed and once you installed it it kept crashing. Also i had a problem when the tablet was charging, you could not use the touchscreen because it doubletaped by itself or taped elsewhere on screen.
The recovery mode was also messed up, unresponsive and could not accept cwm, i managed to get a blank screen at recovery mode after many failed attempts trying to take a firmware backup.
With the new rom all the above problems went away and the tablet works super fast.
I have a 3rd tablet en route from the same vendor, i will flash it with your rom as well it should be a 3rd gen as well.
Regarding the red flash on chrome when scrolling the factory rom had the same bug, havent tried your fix yet cause i dont mind it.
53
2015/01/09 - 09:57
Fine. I am glad the V17HD threads are helpfull for a lot of users. In this price class nobody else will give support.
Anuarbek
54
2015/01/10 - 02:30
Hello! I have a problem, what should I do? I repeated so many times, but nothing works! Please help meIMG_20150110_062610.jpgImage Enlarger
55
2015/01/10 - 02:47
Did you execute eraseIDB?
Anuarbek
56
2015/01/10 - 11:51
I did, I did it by instruction. What should I do
57
2015/01/10 - 13:16
Download file mains the new files don't fit to the current patition layout. EraseIDB will wipe the partition layout. Try again and look to the right windows, current should count up.
reufjaha
Forum Posts: 12
58
2015/01/10 - 13:55
Hi Guys
I'm new one with tablets, ordered chuwi v17hd 1gb 8gb rom , and i dont have google play can you just suggest me which one to flash, i'm not begginer with android flashing but  i want to start correctly just tell me should i follow this topic or previous one , i'm litttle confused. Btw i like this forum it is awesome !
Thanks a lot , Reuf
59
2015/01/10 - 14:04
No HDMI port, I guess. What is the serial-number?
reufjaha
Forum Posts: 12
60
2015/01/10 - 14:22
Yes i dont see hdmi port here i bought from this link
http://www.geekbuying.com/item/CHUWI-V17HD-RK3188-Quad-Core-7-Inch-Android-4-4-OS-Tablet-PC-1GB-RAM-8GB-ROM-IPS-Capacitive-Touch-Screen-1024-600-White-328219/
Build number is rk 3188 - 20141104
baseband version unkwnow
model number is v17hd
kernel 3.0.36+
If you need more info let me know
Thanks, Reuf
Currently Online: POELE
83 Guest(s)
Devices in use: Desktop (64), Phone (18), Tablet (2)
POELE
hststs44
lokeshreddymtpl
scoopsat
Mikewood
XSTR
