[ ROM ] Chuwi V17HD 2nd generation Android 4.4.2 KitKat custom root firmware (2014/09/21)
This is for the model with volume rockers.
doragasu
271
2015/12/03 - 13:33
I have flashed this ROM and the tablet is working, but I don't understand the procedure to flash CWM. When I reboot the bootloader, I cannot see CWM on the list of items to flash on RKAndroidTool. What am I doing wrong?
doragasu
272
2015/12/03 - 22:14
OK, I was missing the step at which you replace the recovery image with the CWM one supplied in the package. Everything works now, big thanks to OMA!!!
273
2015/12/04 - 18:52
Fine.
paspartou
274
2016/02/28 - 20:14
Hello and sorry for my english.
I downloaded probably the version for the genereration with hdmi.
My screen is black and i 'm downloading  this generation rom.
Because i' m newbie can you explain me step by step please how can i install this one?
Unfortunately i cant do usb debugging, my screen is black but i can see the notification in my pc when i connect it but with fail,
my pc doesnt load the drivers.
Windows 7 64bit
Thank you very much.
275
2016/02/28 - 20:42
This is a very old thread here. When you bougth the tab recently it is most likely a RK3126 tab. Can you pls verify this?
paspartou
276
2016/02/28 - 20:47
Thanks for the reply.
My girlfriend bought it 10 months later.
I' m affraid that i can't verify the chip model.
It is with the volume buttons no hdmi. In my country comes with another brand and model name. Turbox breeze iv and i found the official brand and model from forums.
277
2016/02/28 - 20:58
No tab is like the other. Every tab has it's own kernel (hardware abstraction layer). Better ask before flashing something into your tab.
Do you get connection to the Flashtool? Press Reset and then hold Power & Vol+.
paspartou
278
2016/02/28 - 21:00
You mean RkAndroid Tool? It is saying Found Rk Android Loader Rock usb
279
2016/02/28 - 21:16
So, it is not bricked. Try to find the stock firmware. Ask the reseller.
paspartou
280
2016/02/28 - 21:19
I can't find maybe with some command prompt what kernel i need and install something on my own?
So i probably have to pay the reseller to install the stock firmware because of lost waranty, am i right?
281
2016/02/28 - 21:23
You wiped the NAND and the strange kernel is booting. So, there is nothing to do anymore.
Ask the reseller for a firmware download link. In the worst case you have to return it for repair. Yes.
paspartou
282
2016/03/07 - 11:35
Hello again.
My reseller installed the firmware but the playstore can't login to my account.
http://s27.postimg.org/ilhcdyj83/20160303_201132.jpg
http://www.needrom.com/category/others/all-tablets/chuwi/ which one you think is the proper rom?
Sorry for my english.
Thanks a lot!
55 Guest(s)
Devices in use: Desktop (51), Phone (4)
wogoko8553@yubua.com
hellander
elousstad
relaytester
revoltown
