[ ROM ] Chuwi V17HD 2nd generation Android 4.4.2 KitKat custom root firmware (2014/09/21)
This is for the model with volume rockers.
Thowra
256
2015/09/26 - 23:23
Sorry but I had to go to work.
The run after what's the next step?
I read the forum that must copy zip file to the sd card.
Which zip file must copy?
Sorry the lot question but I never install ROM and I would like see every step before start.
257
2015/09/27 - 12:38
No, nothing to copy on sdcard. Just finsh by flashing the CWM.
4) flash the CWM recovery with RKAndroidTool
     a) go to app drawer, open RebootMenue and Reboot to Bootloader
     b) untick kernel, boot, system
     c) load recovery_CWM (klick on the empty box)
     d) Run
     e) tab boots into CWM
     f) reboot system now (both answers are No)
load-file-1.pngImage Enlarger
Thowra
258
2015/09/27 - 16:51
Thanks for your help, the reinstallation is finished ..
I found a 4GB version in the forum #39
If I understand correctly:
The boot and parameter files should be copied from the original pack.
Now it needs to perform the complete installation (IDB erase, RUN, recovery_CWM load).
This is stable version and is compatible with my machine?
259
2015/09/27 - 18:37
Yes, that's it. The add-on is also linked in post #1.
Thowra
260
2015/09/28 - 23:30
Everything works fine, thank you for your help.
danietepa
261
2015/10/04 - 02:16
I have a Chuwi with the following data:
SN: Q8G1150700028
KERNEL: #619
Can I root?
Can I change rom?
That generation is my tablet?
262
2015/10/04 - 02:24
Can I see a screenshot of settings/About the tab?
danietepa
danietepa
263
2015/10/04 - 12:18
Image Enlarger
264
2015/10/04 - 12:24
This is not a RK3188 architecture. I guess it's RK3126. Pls check: https://play.google.com/store/apps/details?id=com.arctablet.cpucheck
danietepa
265
2015/10/04 - 12:41
RK3128
Image Enlarger
266
2015/10/04 - 12:48
Ok, go over to the RK3126 forum and dump the firmware first. Kernel #619 is new.
danietepa
267
2015/10/04 - 13:24
 Ok, thanks, I'll check it out.
disaster2015
268
2015/10/06 - 01:22
Anyway updates to lollipop ? 🙂
wizerd20
269
2015/11/02 - 00:51
Hello! There was a trouble with my CHUWI
When the black screen comes on, the computer sees it, but the driver does not install Windows 7 86x /
According to the model of the tablet CHUWI V17 HD Q8G1141201211
Model CW0858
8gb
No HDMI
I would be very grateful for any help! Thank you.
Sarisss
270
2015/11/10 - 21:47
Hi All,
I have a CHUWI V17HD, serial number Q8G1141200466. I'm running currently ROM "Oma RK31 V17HD 3rd gen 1.0 - 23.12.2014, kernel #848".
Everything seems to be working fine, except the fact that the battery is running not correctly (fast discharging, discharging is not proportional, etc, battery not charging  - sometimes). Do you have any idea what can fix this issue? Do I have to try a different ROM?
Thanks in advance.
208 Guest(s)
2 Guest(s)
Devices in use: Desktop (193), Phone (15)
ppaofe
kabelodinternetu
waterwall
sufak79
ntukinal
Miguelcnc
