[ ROM ] Chuwi V17HD 2nd generation Android 4.4.2 KitKat custom root firmware (2014/09/21)
This is for the model with volume rockers.
Mimyl
241
2015/02/09 - 22:03
Hi Oma,
Thanks for your work. But, for me, it's not working (I'm on windows 8.1 x64 ).
When I try to boot in flash mod and click on "switch" button, I have a message : "device can not switch because of no drive". I have already installed USB drivers.
Do you think you have a solution?
Here is my serial number : Q8G1140900141
Thanks a lot!
EDIT : I found the solution for me. I switch my device with another program ("RKBatchTool V1.7"). After that, I just have to launch your program and follow the step in the .txt
Everything works well now.
Thanks again :)
242
2015/02/10 - 06:34
Fine. However, curious because the two RK-Flashtools sending the same signal.
Win8.1 and the unsigned Rockchip driver are not friends ...
You can also use a key combination (see post #237) to start the tab into flash-mode.
silverstone
243
2015/02/13 - 09:19
hi Oma
I have small problem when I browse the internet with chrome
When I run search the browser starts to go crazy go up and down I scroll down and I see the bar in the middle of the screen again. this thing happens only with chrome, another thing is when I Type in the search bar, its go very slowly - very slow typing  the default browser work ok
Did someone experience a similar problem with chrome?
thanks
244
2015/02/13 - 16:55
Everything fine here.
datmaxle
Krefeld
245
2015/04/11 - 16:13
Hi guys,
My new Chuwi V17HD is here and i've found this site at Google. So my questions are, what Version of the V17HD do i have here?
The SN is: Q8G1141201321
Hardware: no HDMI, Hardware-Volume-Buttons, 1 GB RAM, 8 GB ROM
The Kernel is: #613
The fact is, i've flashed your "2. Gen ROM" with the 613-Kernel and it looks it works good. Except two or three little things.
First is, sometimes i have flashing red borders at Chrome and i hesitate to flash the fix from your "3. Gen-Thread". I don't want to brick these device.
Second is, when i connect the charger, the Touchdisplay becomes nearly unusable. Ghostclicks, wild scrolling and so on happens.
Third is, since i've flahed your ROM, the YouTube-App won't log in to my account. It shows " An Error is accured". Maybe it's not the fault on your ROM, but it's happen since thisthis ROM was flashed.
Could it be, i have to use another Kernel? I'm a little confused by the different tablet-versions from Chuwi. I hope you can give me a hint...
By the way, is there a chance to charge over USB? If not, it wouldn't be a problem, but maybe it can solve the ghostclicks while charging.
Greetings from Krefeld and thanks for all your great work!
Actual Devices:
Chuwi V17HD
OnePlus One 64GB
HP Slate 8 Pro
freiserk
246
2015/04/24 - 11:48
Hi.
My Chuwi V17HD
SN: V17HDQ8G1141200390
Kernel: #814
Is V2 ?
Many thanks
datmaxle
Krefeld
247
2015/05/27 - 13:19
Still no answer? Impressive!
This tablet seems to be the worst crap. Now it becomes extremely hot when charging and starts to smell like burned plastics. And there is a extremely loud ticking or knocking sound from the speaker. This sound is there even when the tablet is switched off. It drives me crazy!
There is a soundfile with the recorded ticking sound. https://www.dropbox.com/s/oo0sgwkmybgvrof/PTT-20150526-WA0001.aac?dl=0
Actual Devices:
Chuwi V17HD
OnePlus One 64GB
HP Slate 8 Pro
248
2015/05/27 - 16:24
Obviously a hardware defect.
Fredvanl
Forum Posts: 15
249
2015/06/23 - 01:10
Ok, the new firmware for tabs starting with S/N Q8G1141100214 is provided on Chuwi forum: http://bbs.chuwi.com/forum.php?mod=viewthread&tid=253&extra=page%3D1
It includes a new kernel #848 preempt 26. Nov 2014.
Build is still old, compiled 7. Oct 2014. Display Id is a fake.
ro.build.id=KOT49H
ro.build.display.id=rk3188-20141127
ro.product.model=V17HD
ro.product.brand=CHUWI
ro.build.description=rk3188-eng 4.4.2 KOT49H eng.root.20140710.101113 test-keys
ro.build.fingerprint=rockchip/rk3188/rk3188:4.4.2/KOT49H/eng.root.20140710.101113:eng/test-keys
I will not do a new build, as build in post #1 adresses all what can be done. Let me pls know "bad" behavior of the new kernel, like other orientaion. I will do a fix.
Hi Oma,
Thanks for all yur work..
"Bad behaviour"in the build in the first post with the 848 kernel is that the OMA LOGO and the Android recovery menu are upside down.
Can yu do a fix for those please?
TIA
Fred
disaster2015
250
2015/09/26 - 00:49
Hi people, i have one cw-v17hd i think that is 2 version .... i want install a modification rom because my tablet have some problems ...
- Reboot in browser
- Sometimes some glitch in image 🙁
This problems with stock programs ....IMG_20150925_124302.jpgImage Enlarger
ANYONE with same problems with stock software ?
251
2015/09/26 - 13:09
Kernel xingyu #515 identifies it cleraly as 2nd gen.
Thowra
252
2015/09/26 - 19:04
hi Oma,
I bought one used Chuwi tabtet.
Model: CW0858
Serial: V17HD Q8G1141001073
8Gb with phisical volume buttons and no HDMI connector.
The old user install you're ROM to this tablet.
He modifies some things.
I would like reinstall you're original ROM.
I downloaded Oma_RK31_Chuwi_V17HD_2ndgen_KK_4.4.2_v1.1
This is the last stabile version?
I installed USB driver and start RKAndroidTool.
I switch off the tablet.
I press and hold VOL + button > connect USB cable > press power button until RKAndroidTool write : Found RKAndroid Loader Rock Usb.
I never install ROM :(.
Can you help me (step by step).
Sorry my english.
version screenshot
253
2015/09/26 - 19:31
Ok, also kernel #515. The tab is now in flash modues (Found Loader Rock Usb). Press eraseIDB first, then Run.
Thowra
254
2015/09/26 - 20:00
Ok, what's the new step?
255
2015/09/26 - 20:01
So, you are in Android now?
206 Guest(s)
Devices in use: Desktop (191), Phone (15)
ppaofe
kabelodinternetu
waterwall
sufak79
ntukinal
Miguelcnc
