[ ROM ] Chuwi V17HD 2nd generation Android 4.4.2 KitKat custom root firmware (2014/09/21)
This is for the model with volume rockers.
226
2015/02/07 - 10:44
The answer to your edit is No.
USB charging or not depends on the kernel. You can check the kernel #814. Flash it into the running build, just tick parameter and kernel. To load a kernel into the RKAndroidTool click on the empty box at the end of the kernel line.
Piter_23
227
2015/02/07 - 11:15
And could you rub my nose in the core, which would fit on my plate and it would support charging by USB?
Thank You!
228
2015/02/07 - 13:08
For your tab only the two kernel #814 and #848 are available. No idea if they support USB charging.
Piter_23
229
2015/02/07 - 17:22
I was at the sink firmware kernel # 814
and after the firmware on your, became the core of # 848
In none of the cases charging via USB tablet - no!
Could you do magic and modify firmware for 3rev Chuwi V17HD ability to charge through the USB?
230
2015/02/07 - 17:48
Chuwi did not publish kernel sources. Sorry.
h3v1l
231
2015/02/09 - 17:07
Hi, Oma!
I've just received my Chuwi V17HD and I'm trying to understand which model it is and which one of your roms I should flash.
The tablet has got no HDMI port and there are volume buttons.
The model number on the back is: Q8G1141201457
The kernel version is: 3.0.36+ root@xingyu-desktop #515
Play Store and other Google Apps are alredy installed and work perfectly.
This is my first android device, so I will probably need some further help during the process! To start I have to follow the instructions in the post #61 and the ones contained into the file on post #1, am I right?
Actually I don't have a micro sd to use with this tablet, can I still use the add on to increase the internal storage to 4GB? When I will buy the sd card, I will have to flash your custom rom again from the start to swapp the mounts?
Thanks a lot in advance for your great work! Smile
232
2015/02/09 - 17:26
Thanks for providing your data! It is not easy to find out what's going on here: http://www.arctablet.com/blog/forum/crewrktablets-rk3188-entwicklung-customroms-development-croms/rom-chuwi-v17hd-2nd-generation-android-4-4-2-kitkat-custom-root-firmware-20140921/page-13/#p50223
Your tab is 2nd gen. 500 MB or 1 GB RAM?
No need to dump the firmware.You can use the build in post#1 as is.
To increase the internal storage to 4 GB just use the parameter file from the add-on.
When swapping mounts in any case I strongly recommend a clean install.
h3v1l
233
2015/02/09 - 17:51
Thanks for the fast answer!
It has got 1GB RAM. I can provide any other information you need! Laugh
Now I'll try to flash the build in Post #1 and let you know!
EDIT 1: One question: the process to gain root access is included in one of the steps of the Instructions.txt file?
EDIT 2: I've successfully installed the drivers but when I open RKAndroidTool and I press the "Switch" button it says: "Device can not do switch,because of no drive". Below it is written: "FoundRKAndroid Mass Storage USB". There is something I have to do first to put the tablet into flash-modus?
234
2015/02/09 - 19:37
Which windows? Did you enable USB debugging?
h3v1l
235
2015/02/09 - 19:45
Windows 7 Home Premium
Yes, it is enabled! I can also see it within the notification panel!
Here is what I see:
Error_RKAImage Enlarger
h3v1l
236
2015/02/09 - 19:51
There is something more I have to do, apart from checking the "Debug USB" option in the developers menu?
Devs_opt
237
2015/02/09 - 19:56
Power off. Hold Power and Vol+ until "Found ..." is shown.
h3v1l
238
2015/02/09 - 20:09
I did it. Now the tablet screen is off, but when I press "Switch" it says: "Device can not do switch,because it is not msc device". Cry
239
2015/02/09 - 20:11
Sure, the tab is off. Use the keypad.
h3v1l
240
2015/02/09 - 20:48
Great! It worked! I'll try it and let you know! Thanks a lot for your patience! Laugh
207 Guest(s)
Devices in use: Desktop (189), Phone (18)
ppaofe
kabelodinternetu
waterwall
sufak79
ntukinal
Miguelcnc
