[ ROM ] Chuwi V17HD 2nd generation Android 4.4.2 KitKat custom root firmware (2014/09/21)
This is for the model with volume rockers.
adrian.greek
Forum Posts: 13
211
2015/02/01 - 18:43
can you put a link for stock rom please ?
adrian.greek
Forum Posts: 13
213
2015/02/01 - 19:21
ok thanx for your time
adrian.greek
Forum Posts: 13
214
2015/02/01 - 19:22
coul you recommand a tab under 80$ with customs roms ?
215
2015/02/01 - 19:53
V17HD is very unique in the price class. Look for the upcoming RK3126 tabs (around 60$) or better RK3128 with 1 GB NAND (around 80$). However, there are no custom roms yet.
Currently best tab for the money is in my view the Pipo P7, which is RK3288. You will find it for around 140$. RK3288 is well supported by the community.
daquark
216
2015/02/05 - 23:59
I thought I had a 2nd generation Q8G1141200258, so I installed the 2nd generation flash. After that I had a a black screen with dancing blinking dots !!!
I was afraid I bricked the tablet.
Then I found out Q8G1141200258 had kernel 814 and it is a 3rd generation.
I was still able to connect to the tablet with the 3rd generation flash files.
Now it works perfect !!!!!!!!!!!!!!!!!
Oma a lot of cudo's for your work because of you we have a very nice tablet with all possibilties !!
Piter_23
217
2015/02/06 - 13:19
Good day!
I Chuwi V17HD RK3188 with volume buttons no HDMI and 1G of memory marked on the back cover V17HD Q8G1141200505
Runoff firmware build number rk3188-20141104
I have a problem with GooglePlay
What is the most stable firmware version on my tablet that worked GooglePlay?
Thank You!
riempje
218
2015/02/06 - 13:56
I would like to install your (2nd gen) rom to my new Chuwi v17HD; is my tablet is indeed a second gen?
No hdmi, just volume keys
Model CW0858
Q8G1140900239
android 4.4.2, kernel: 3.0.36+ #515 xingyu 3sept2014, build# cw-v7hd-20140904
219
2015/02/06 - 16:07
Yes, with kernel #515 the tab is 2nd gen.
riempje
220
2015/02/06 - 16:10
Piter_23 said
Good day!
Thank You!
Difficult in this serial number range ... what is the kernel number?
221
2015/02/06 - 17:24
daquark said
Ok, fine. Other thread deleted.
Piter_23
222
2015/02/07 - 07:51
Piter_23 said
Good day!
Thank You!
kernel version:
3.0.36+
root@xingyu-desktop #814
Thu Nov 20 14:33:51 CST 2014
Piter_23
224
2015/02/07 - 08:27
Thank you so much!
I thought that this is the firmware needed!
THANK YOU! I will try!
p.s.
and these firmware I think that it is not for my tablet?
Update 29.01.2015: if the running kernel is #613 pls see here.
http://www.arctablet.com/blog/forum/crewrktablets-rk3188-entwicklung-customroms-development-croms/rom-chuwi-v17hd-2nd-generation-android-4-4-2-kitkat-custom-root-firmware-20140921/page-13/#p50223
Piter_23
225
2015/02/07 - 10:39
Please indicate your firmware - everything works fine! Thank You!
But there is a question as to why there is still charging via USB-port?
Some people, I ask your firmware versions 3.3 and 3.4 say that there was a charge via USB.
What you need to and firmware version 1.0 for core # 814 also has the ability to charge via USB?
And yet hotielos to get an answer to my question from the previous post:
p.s.
Thank You!
196 Guest(s)
Devices in use: Desktop (183), Phone (13)
ppaofe
kabelodinternetu
waterwall
sufak79
ntukinal
Miguelcnc
