Gents,
There is a new hardware revision of the Chuwi V17HD in the field.
Chuwi did not announce that, so let's call it 2nd generation
Hardware components are quite different from the 1st gen.
You can identify 2nd gen tabs by the missing HDMI port. Instead of this there are volume rockers.
Do NOT flash this firmware or kernel into Chuwi V17HD 1st gen!
We do have some confusion here ... read from post #24.
Update Dec 2014: another undocumented hardware revision is in the field and can be identified
by Serial-Numbers starting with Q8G141100214. Pls use the 3rd gen build.
V17HD 2nd gen by Oma KitKat build v1.1
– system ext4
– selinux kernel xingyu #515 preempt 03. Sep 14
– internal storage 2,0 GB
– device spoofed as Nexus 7
– ethernet support
– init.d support
– gameloft compatible
– USB-Hub enabled
– Dateimanager HD (Root)
– Nova Launcher
– full gapps support
add on to increase internal storage to 4 GB and swapp mouts.
hints:
>>> Pls make sure to execute eraseIDB first in RKAndroidTool.
- use of CWM: wipe up/down to scroll – Power to execute – wipe right to go back
– Oma -
lancillotto75, zacharias99, WiwiPouPou, MrLaMe, silverstone, german_psycho, riempjePer aspera ad astra, we rock the Tablets !
2014/09/17
Same thing for me , i try to flash it and now only a black screen.
It download the flash to the tablet without problems. then it check the download data and size and the last message on the rkloader is : Info : Run ok
Edit : i dont know how but the oma boot screen appear , then freeze... now its just dead ! Nothing works.
2013/09/02
jean-seb said
Same thing for me , i try to flash it and now only a black screen.It download the flash to the tablet without problems. then it check the download data and size and the last message on the rkloader is : Info : Run ok
Solution is described in http://www.arctablet.com/blog/forum/crewrktablets-rk3188-entwicklung-customroms-development-croms/rom-chuwi-v17hd-android-4-4-2-kitkat-custom-root-firmware-20140402/page-16/, message #235
Guys, I have had some trouble uploading the pack to our server. Maybe the download is not ok.
Re-upload is available under the link in post #1. Flash again incl. eraseIDB.
Try to start the tab into flash modus with the reset button (hope it is still there):
- long press reset
- hold vol up and press reset
- hold power on and press reset
Specs 2nd gen:
- Touchcontroller: ct69x (1st gen: icn85xx)
- Wifi: esp8089 (1st gen: nmc1000)
- Audio: es8323 (1st gen: rk616)
- Sensor: mxc6225 (1st gen: stk831x)
This is a complete different tab.
How is the screen? Is it still IPS (good viewing angles in any direction)?
Could you remember which kernel was on your tablet?
2014/09/25
Hallo Oma,
I am new to this forum and I found you as I bought a Chuwi v17HD from tinydeals.
The problem is that I got the hardware button Version and my kernel is kernel xingyu #503!
Should I try flashing this ROM or will there be a problem you think?
I am asking because I see many people having problems with black screens and I am little confused about what to do!
Thank you for your help and your work!
Zaxos
Unfortunately I cannot test the build with the xingyu #503 kernel on my Chuwi 1st gen. The build in post #1 runs fine with my kernel. So, the risk is the kernel. When you have the same kernel it should work. But again, there is a risk. Maybe one should wait until Chuwi provides the stock firmware.
Which rom?
Currently Online: alex.z76
102 Guest(s)
Devices in use: Desktop (75), Phone (28)
alex.z76
Lauviah06
miche58092
travels2nepal01
picman
alex.camunas
