[ ROM ] Ceros Revolution CT9716 Android 4.4.2 KitKat custom root firmware (2014/06/10)
Sowden
61
2014/12/30 - 19:56
Ok, the first pic is the hub plugged in, the second is whats plugged into the hub.  Lets try uploading these pics.Screenshot_2014-12-30-19-52-03.pngImage Enlarger
 Screenshot_2014-12-30-19-52-29.pngImage Enlarger
tonybod
62
2016/05/23 - 10:01
Works still fine on my tab. Not really an idea.
Do a clean install again and if the effect is still there change the wifi driver:
http://crewrktablets.arctablet.com/?wpfb_dl=695
http://crewrktablets.arctablet.com/?wpfb_dl=1417
http://crewrktablets.arctablet.com/?wpfb_dl=1485
Really quick question hopefully. I seem to have the same problem with WIFI.
How do I go about installing these? Do I just copy the files within the zip to the relevant paths on the tablet?
Thanks as well for this ROM. My tablet has been "unloved" for a long time, it was so slow making it unusable unless you had a lot of time to wait for it to boot up and get ready. This ROM makes it very usable.
Tony.
Thanks Received: 1378
63
2016/05/23 - 17:37
Put them on the external sdcard and reboot into the CWM recovery. Then install fix from external sdcard.
tonybod
tonybod
64
2016/05/24 - 17:45
Many thanks. The first file fixed the wireless speeds for me. I did have another problem where it would not connect to a certain access point, I'll test that later when I get home.
I also tried to encrypt the tablet, but it failed (luckily I had done a backup from within CWM). Should encryption work?
65
2016/05/24 - 19:00
I never used encryption on one of my tabs. I see however no reason why that should not work.
tonybod
66
2016/05/24 - 19:14
Thanks again. I'll give it another go later on.
I'm still having some WIFI issues. It can see the router, and starts connecting, but then fails at the authentication stage. All other devices in the house work fine with the router. Any suggestions?
tonybod
67
2016/05/25 - 08:13
The tablet encrypted fine the 2nd time. Strange.
tonybod
68
2016/06/02 - 20:40
Is there a more up to date wifi driver for this tablet?
I find I can get it to connect to the router if I reboot, but as soon as I go to a different network, I can no longer re-connect to the original router unless I reboot. Does that make sense? If I disable the wifi and re-enable it, same again, it cannot connect. In all cases, it can still see the router, just not connect.
The router is a TP-Link Archer C8, so fairly recent. None of the other devices have trouble, just the Ceros.
114 Guest(s)
Devices in use: Desktop (64), Phone (48), Tablet (2)
El1as
texet1234
1234dafa
tristoufff
zerozero
jhgjhg
