[ ROM ] Ceros Revolution CT9716 Android 4.4.2 KitKat custom root firmware (2014/06/10)
Thanks Received: 1377
46
2014/12/29 - 20:53
Thank you for feedback!
Did you let superuser install a script?
Open a terminal and let me have the result of lsmod.
Sowden
47
2014/12/29 - 21:17
Install a script?  What script do I need to install?  And I assumed that you wanted the hub plugged in when I took the screenshot?  Is this what you wanted?  Thanks man.
http://troyh.us/FTPshare/pieproductions/Screenshot_2014-12-29-21-11-12.png
48
2014/12/29 - 21:23
With latest superuser updates there is an offer to install a script which could kill the init.d support.
Not ismod, type lsmod.
Sowden
49
2014/12/29 - 21:39
Opps, my bad.  Heres an image, and let me look through superuser.
http://troyh.us/FTPshare/pieproductions/Screenshot_2014-12-29-21-25-35.png
50
2014/12/29 - 21:55
Ok, kernel modules are not running. Pls install this via CWM: http://crewrktablets.arctablet.com/?wpfb_dl=2337
Superuser will ask to update binary. Confirm.
Reboot and let me see the result of lsmod.
Sowden
51
2014/12/29 - 22:15
I never got CWM installed, I got stuck in the instructions.  I never found where to load recovery_CWM in RKAndroidTool.  Could you give me some advice?
52
2014/12/29 - 22:17
See picture.
load-file-3.pngImage Enlarger
Sowden
53
2014/12/29 - 22:19
Oh, so I just change the name?  Alright, I'll flash it now.
Edit: Got it, but the link is now broken :\  Sorry man.
Edit Edit: I am messing around with CWM, but I can't find a way to make my courser move.  I only have a physical "Back" and "Power" button.  The Back button seems to do nothing but the power button selects.  How do I move a courser?  Sorry for being a noob, thanks.
54
2014/12/30 - 09:22
You can download now. CWM has touch support.
Sowden
55
2014/12/30 - 17:41
Got it.  But it seems like there is no touch.  I have version 6.0,3.1 by OMA.
56
2014/12/30 - 17:45
Ok, when you cannot swipe to scroll then your kernel provides no touch event.
No volume rockers, no touch ... use an usb mouse to navigate.
Sowden
57
2014/12/30 - 17:54
Dang it, a mouse is a no go.  It losses its power right as it goes into CWM.  Is there a touch version for the Revolution that I don't have?
58
2014/12/30 - 19:09
No, the included CWM supports touch, but it seems your kernel doesn't support it. Very untypical.
Anyway, then we start the zip from Android ;-)
Copy the zip to your internal sdcard and load Nandroid Manager from Play Store. Flash Zip(s) via Recovery (see screenshot).
Result of lsmod.
zip_via_nandroid_manager.pngImage Enlarger
Sowden
59
2014/12/30 - 19:37
Oh ok, got it all.  Here you go.
http://troyh.us/FTPshare/pieproductions/Screenshot_2014-12-30-19-31-43.png
Edit: Just tried the hub, but no dice.  I should mention that I am trying a self powered and externally powered hubs.
60
2014/12/30 - 19:47
Ok, the kernel module to enable the hub is running.
Open the included app USB Host Controller, plug an simple hub in and let me see the result.
v1.1_04.pngImage Enlarger
112 Guest(s)
Devices in use: Desktop (106), Phone (6)
bstnnetwork
dim1988
delury
digitalspider
rorororo
gnfkojgnegj
