This is a generation 2 loader KK build for high-resolution tabs and MT5931 wifi  Â
Revolution by Oma KitKat build v1.0
– system ext4
– selinux kernel dont #481 preempt 28.04.2014
– internal storage 4 GB
– ethernet support
– init.d support
– gameloft compatible
– USB-Hub enabled
– Dateimanager HD (Root)
– Nova Launcher
Gen2 loader firmware will frequently generate trouble for the user. So, please read
the instructions carefully to understand how to change between gen1 (v1.24 loader)
and gen2 (v2.10 loader) firmware.
hints:
– to improve UI feeling disable animation scales in developer options
– to disable su notifications change notification in su app
– to prettify the build use Xposed Framework > Starterpack
Thanks to kasty
 – Oma -
pargas, LordlucanPer aspera ad astra, we rock the Tablets !
Use instead of Vol-up the Back button.
chris91300,
Kasty firmware is based on the manufacturer stock firmware. It brings root and some customizations but Oma firmware has some extras. Oma and Crew RKTablets work is solid stuff, but your mileage may vary as there are some subtle differences on Android Rockchip tablets out there. Users really need to test and make their opinion. Posting bug reports also helps tweaking and improving both firmwares.
I see no problem doing that.
2013/04/23
Here's a preliminary report;
1. Creating a CWM package with just the boot, kernel and system images did not work. I had to install the full ROM (but I created a parameter file for 7GB). It seems that whatever the stock recovery does after first boot is necessary (meaning that a CWM package will not work, unless it also installs the stock recovery).
2. Most things seem to work as expected (so far).
3. Antutu score of 19,800 after first boot. 19,500 subsequently.
4. Something has gone awry with the boot logo; you get an "Oma" image with lightening flashes, then a black screen for a couple of minutes, while the tablet finishes booting – it is easy to think that the tablet had become bricked, but waiting patiently revealed that it had not.
More later …
2013/04/23
Further report:
1. Continues to be stable
2. With slightly overclocked kernel, Antutu score goes up to 20,558
3. Serious issue with wireless. Something is seriously wrong with upload speeds, either on the internet or in the LAN. It is down to 0.35 mbps average, when it would normally average 7mbps. Download speeds are quite fine.
Which wireless drivers are included in the ROM ?
I can't reproduce this. Anyway, thank you for testing!
80 Guest(s)
Devices in use: Desktop (73), Phone (6), Tablet (1)
jackthomas
hakhiem
jenom
kfwacky
fer30
culo1
