[ ROM ] Aoson M33Q Android 4.4.2 KitKat custom root firmware (2014/06/30)
61
2015/01/10 - 13:19
So, this gives us the question which tab / hardware revision do you have.
jepa
Forum Posts: 12
62
2015/01/11 - 15:21
If I read dmesg output correctly, the touch is vtl ct36x, WiFi+BT:AP6330 and e.g. 5 Mp camera is ov5640. The whole output with the latest stock rom code from http://www.rockchipfirmware.com/node/272 is attached.
Jepa
63
2015/01/11 - 15:25
Well, this is a M30Q not M33Q ;-)
jepa
Forum Posts: 12
64
2015/01/11 - 15:54
Wow - somebody seems to be blind with numbers... Cool
When comparing the specs of these two devices, I was able to detect only the rear camera difference. Or do you have some further info? Also touch is different?
How to proceed? I'd love to go for KitKat...
Jepa
65
2015/01/11 - 16:26
More then blind ... that cost you a beer!
We know 4 hardware revisions of M30Q: http://www.arctablet.com/blog/forum/crewrktablets-rk3188-entwicklung-customroms-development-croms/rom-odys-iron-omnirom-4-4-2-custom-root-firmware-20140530/page-18/#p48068
You can check out the latest Omni build: http://crewrktablets.arctablet.com/?p=3555
Try the latest build v1.4.1 and use the kernel and the fixes documented under Love Li Shun. Make sure you are on a gen1 loader before flashing the build. If you run the Love Li Shun stock for now, you are.
jepa
Forum Posts: 12
66
2015/01/18 - 16:42
Thanks Oma,
I followed the odys-iron-omnirom link above. The challenge was to find the right combination of files to get correct display and camera orientation. Finally after some trial & error (tried I think ~5 model fixes) I ended to Aoson M30Q Love Li Sun kernel + model fix from Aoson M30Q GT911 touch panel.
Now everything seems to work and is pretty smooth. The only non-smooth item is the automatic display rotation. It takes a while until the display settles. I don't know if this is a known issue - video is attached.
 Anyway, many thanks for your support. And yes, I owe you a beer.
Jepa
kokata
67
2015/01/25 - 11:33
Hey Oma, please add SDK V2 ☺
68
2015/01/25 - 11:35
What should I add?
kokata
69
2015/01/25 - 11:39
What should I add?
http://www.slatedroid.com/topic/78585-rk3188-sdk-20/
70
2015/01/25 - 11:41
Well, this was Jelly Bean. Now we have Kitkat ;-)
kokata
71
2015/01/25 - 12:08
Ok ☺ Browser slightly lags, recommend me someone goes smoothly. Use google translator ...
jordi08028
72
2015/02/03 - 11:11
I've tried to install your custom firmware KK in a genuine Aoson M33Q, which had (already has) installed the stock KK firmware from Aoson web. Mine is model LX (M33Q), not GB (M33QS).
I'm doing all stuff in a windows 7 64bit. I could install the drivers from step 1, but in step 2, when entering flash mode, windows recognizes my device as a "Rockusb device" with a blue quotation (?) on the icon, but RKAndroidTool keeps saying device Not found. I've tied to force driver to a RK31 device, but no luck with RKAndroidTool.
Any idea or suggestion?
Thanks in advance!
Jordi
thana54
73
2015/02/03 - 12:40
To all M33 owner, what is your average idle battery life ?
I can't get 2 days straight, doing only 10min wifi per mornings.
The cpu seems to adapt (312MHz minimal) when sleeping. I don't know what is draining all the battery :(
raz_20
74
2016/12/29 - 10:49
I have a tablet that looks like the Aoson m33q, i have the same problem of inverted touch screen (upside down), is there any solution ?
thank you
61 Guest(s)
Devices in use: Desktop (56), Phone (5)
tdomnic024
otismaibe
Tsuna77
docentik2006
nechey
