[ ROM ] Aoson M33Q Android 4.4.2 KitKat custom root firmware (2014/06/30)
jepa
Forum Posts: 12
46
2015/01/06 - 19:04
Power supply plugged?
No effect if plugged or unplugged. Device manager shows Android ADB Interface. - Jepa
Thanks Received: 1378
47
2015/01/06 - 19:31
Then the usb flash-driver are not installed properly. Which windows?
jepa
Forum Posts: 12
48
2015/01/06 - 19:58
64bit Win7. Which driver should be active in the PC end? - Jepa
49
2015/01/06 - 20:09
There is an included driver assistant. Use an other usb port and run the assistant. Uninstall first, then install.
jepa
Forum Posts: 12
50
2015/01/06 - 20:38
Hi Oma,
I changed the usb port, uninstalled (ok) & installed (ok) with the assistant. USB rock class + Android device drivers were installed.
I started the RKAndroidTool and rebooted the device pressing power + volume-up. Still I get the recovery tool on the tablet and No found-message.
I updated the FW last autumn from Aoson's official site. Kernel is 3.0.36+ (27-Sep-13) and FW is rk30sdk-eng 4.2.2 JDQ39 eng.root.20130927.170414 test-keys. Recovery system, which always gets activated, is 4.2.01. There are options to update e.g. from ADB. You may be familiar with this recovery system...
This seems to be tricky. I don't know if it is button sequence or something else - starts to be frustrating. Could I download the packages using recovery system or potentially update the device e.g. using linux machine - I have win/xubuntu dual boot pc's?
Many thanks for your great support - Jepa
51
2015/01/06 - 20:44
Same usb flash driver.
Unplug the power supply and hard power-off (press power for about 12 sec, until screen goes black). Hold vol+ and plug power supply.
jepa
Forum Posts: 12
52
2015/01/06 - 21:01
I tried hard power-off (pressed ~1 min), but the screen did not go black and M30Q did not boot. Options to shut-down, flight mode or silent mode were given...
Jepa
53
2015/01/06 - 21:04
Hm, does the tab have a Reset? Otherwise shutdown and try.
jepa
Forum Posts: 12
54
2015/01/06 - 21:15
There is a reset button you can access with paper clip. I have pressed that and always the device goes to recovery system menu when power & vol+ are pressed.
Jepa
55
2015/01/06 - 21:17
This is the normal behaviour when the power supply isn't plugged.
jepa
Forum Posts: 12
56
2015/01/07 - 18:21
Charging LED is constantly red indicating plugged charger. Still it goes to  recovery system menu.
Jepa
57
2015/01/07 - 19:18
Unplug the power supply and power-off. Hold vol+ and plug power supply.
jepa
Forum Posts: 12
58
2015/01/07 - 19:32
Nope. It goes to recovery system menu...
I start to be desperate. Any other means to enter flash mode?
Jepa
59
2015/01/07 - 19:59
Is there still a firmware on the tab booting?
jepa
Forum Posts: 12
60
2015/01/10 - 11:51
I finally managed to get the tab to flash mode by pressin vol down instead of vol up.
Flashed the 30-Jun-14 version with which touch was inverted etc. Furthernore e.g. WiFi and BT did not work.
Flashed again with 05-Jan-15 kernel. Still touch does not work. Y->-X, X->Y. WiFi and BT do not work.
Any idea if these can be fixed? Many thanks for your support.
Jepa
65 Guest(s)
2 Guest(s)
Devices in use: Desktop (60), Phone (4), Tablet (1)
gaecraco1
gaecraco
freem
geokgian
s_t_y_m
tomasomsk
