[ ROM ] Aoson M33Q Android 4.4.2 KitKat custom root firmware (2014/06/30)
Thanks Received: 1378
31
2014/12/06 - 18:21
<5>[    0.000000] Linux version 3.0.36+ (root@ok-desktop) (gcc version 4.4.3 (GCC) ) #202 SMP PREEMPT Thu May 16 10:31:44 CST 2013
<6>[    4.830851] input: ct36x_ts as /devices/virtual/input/input1
<4>[   33.522743] Realtek 8188EU USB WiFi driver (Powered by Rockchip,Ver 1.12) init.
Ok, still 4.1.1. There is kernel #188 preempt 8 May 13 in the archive: http://crewrktablets.arctablet.com/?wpfb_dl=1588
You can check out the Omni build: http://www.arctablet.com/blog/forum/crewrktablets-rk3188-entwicklung-customroms-development-croms/rom-odys-iron-omnirom-4-4-2-custom-root-firmware-20140530/
patdut
patdut
32
2014/12/07 - 09:34
Thank you Oma,
If I understand, I have to flash the kernel and the rom. That's it ?
More over, i need to install CWM on the tablet and i don't find one that fit it. (DONE)
As I am a newbie in this kind of operations I might need a step by step notice. Have you some that can help me or give me a link to a good one ?
Thanks by advance
Ragards
Pat
patdut
33
2014/12/09 - 08:56
Hello Oma,
I hope to get soon an answer to my questions.
One more question:
Is the Odys Iron a carbon copy of the Aoson M33 ?
Regards
Pat
saravanansb
34
2014/12/09 - 11:46
Hi Oma,
    I installed the fix from http://crewrktablets.arctablet.com/?wpfb_dl=2288 as suggested but it has reversed the orientation and still the touch issue remain unchanged - Also the screen display area has diminished.
- SB
saravanansb
35
2014/12/09 - 11:57
Attaching kernel log for more info
36
2014/12/09 - 14:19
That means the Lenovo S2500A has an other touch controller. So M33Q kernel wont work for you.
saravanansb
37
2014/12/10 - 05:27
Hi Oma,
 Can we find out the type of touch controller in my tablet ? or any way to try other kernels ?
Note: I have CWM back up of the original JellyBean ROM that I had before on my tablet which works fine for touch.
-SB
38
2014/12/13 - 15:24
Ok, upload boot.img, kernel.img and system from that backup. I will check.
thana54
39
2014/12/27 - 19:52
I've got an Aoson M33 since 1 week and tried every roms i could find (even MIST rom beta2)
Oma, you're rom give my inverted touchscreen.
I've contacted my vendor and he's given me another 4.4 rom (without root).
Here's the link: http://mail.qq.com/cgi-bin/ftnExs_download?k=6c34343091a55084a4bdff2843310349020304545c01060319510309071c0550525519515500534b520c0d0304030855000450036512311344505544006e5c5507456b510b5543095d50001e516e5009475b5a6f22731f0f5953340d&t=exs_ftn_download&code=4440e11f (i can upload it elsewhere if need be).
This one is good with touchscreen, but à've good huge battery drain because of Mobile Network signal. I can't turn it off, even in aeroplane mode :(
Do you know a way to root android 4.4 ? I can push the binaries, but superSU can't find the su binary.
Screenshot_2014-12-27-19-25-52.pngImage Enlarger
 Screenshot_2014-12-27-19-26-08.pngImage Enlarger
 Screenshot_2014-12-27-19-49-00.pngImage Enlarger
The following users say thank you to thana54 for this useful post:
gagou
40
2015/01/05 - 10:37
Ok, a new hardware revison "GB".
Here is the kernel: http://crewrktablets.arctablet.com/?wpfb_dl=2352
Change it in folder rockdev/Images and flash again, incl. reaseIDB.
gagou, thana54
gagou
41
2015/01/05 - 20:27
Thank you a lot Oma and thana54 !
I followed Oma's instruction from his last post and my touch screen works now without inverted axis :D
Oma, out of curiosity, how did you convert thana54's firmware to your kernel ?
42
2015/01/05 - 21:22
Fine.
I just extracted the kernel out of this firmware.
saravanansb
saravanansb
43
2015/01/06 - 13:20
Thank you very much to Oma and thana ! -  The same problem I had with touch input is fixed now...
jepa
Forum Posts: 12
44
2015/01/06 - 18:16
This is a generation 2 loader KK build for high-resolution tabs and RTL8188 wifi   ;-)
M33Q by Oma KitKat build v1.0
update 05.01.2015:
new hardware revision in the field, called GB: here is the kernel (change in folder rockdev/Images before flash)
– system ext4
– selinux kernel ok #4 preempt 09.05.2014
– internal storage 4 GB
– ethernet support
– init.d support
– gameloft compatible
– USB-Hub enabled
– Dateimanager HD (Root)
– Nova Launcher
Gen2 loader firmware will frequently generate trouble for the user. So, please read
the instructions carefully to understand how to change between gen1 (v1.24 loader)
and gen2 (v2.10 loader) firmware.
hints:
– to improve UI feeling disable animation scales in developer options
– to disable su notifications change notification in su app
– to prettify the build use Xposed Framework > Starterpack
 – Oma -
M33_01.pngImage EnlargerM33_03.jpgImage EnlargerM33_02.jpgImage Enlarger
Hello Oma,
Many thanks for your great work!
I believe I have been able to successfully install the drivers (step 1). Furthermore, I was able to earlier flash my MK802IV with Rockchip BatchTool v1.7.
Due to some reason, I'm stuck with the step 2 "start the tab into flash-modus". My M33Q goes to system recovery (3e) when booting with power and volume + pressed, but RKAndroidTool shows constantly "No found". When the M33Q is in mass storage, RKAndroidTool founds it as mass storage.
I am a beginner so maybe the flaw is between the seat the keyboard. Any hint will be appreciated!
-Jepa
45
2015/01/06 - 18:50
Power supply plugged?
93 Guest(s)
Devices in use: Desktop (80), Phone (12), Tablet (1)
jone2122
NOnoS
ammie
Andreasse
richard0085
saradavis1
