[ ROM ] Aoson M33Q Android 4.4.2 KitKat custom root firmware (2014/06/30)
saravanansb
2014/12/01 - 17:33
Hi Oma,
 Any progress with the touch screen issue - I too have the same problem of touch inversion after ROM update - If I touch the screen at the bottom , it senses at the top when tablet is in horizontal position. Any help would be of great timing as I see this ROM is perfectly working fine for other funcionalities.
-SB
Thanks Received: 1377
2014/12/01 - 18:58
This indicates that the kernel won't fit for your hardware. Which tab is it exactly?
saravanansb
2014/12/03 - 12:48
Hi Oma,
Mine is a Chinese tablet("Lenova - S2005" but not original lenova I guess) and hence not sure about the hardware - bought by one of my friends who traveled to Beijing - Any possibility to try other Kernels safely?
As seen from CPU-Z 10.1 inch , 1.61 GHZ quad core, Rk3066, cortex-A9, GPU ARM Mali-400 MP, internal storage 4GB, 2GB RAM, Screen resolution : 1536x2048, 264 dpi, Wifi and all other common sensors
- SB
2014/12/03 - 17:05
Let me have a dmesg log. You can identify the CPU with this app: https://play.google.com/store/apps/details?id=com.arctablet.cpucheck
saravanansb
2014/12/05 - 08:06
Hi Oma,
   I have attached the logs and the screenshot of my tablet configuration - please let me know your valuable comments or suggestionCpu_check.jpgImage Enlarger
2014/12/05 - 18:16
Ok, that is a RK3188 ... and it looks like your run the build from post #1.
saravanansb
2014/12/05 - 19:13
yes, any finding from the kernel log and would you suggest an alternative ROM or Kernel fix to make use of the touch screen :-)
-SB
2014/12/05 - 19:19
Not really, the log starts at 314 sec. What is the problem?
saravanansb
2014/12/06 - 00:26
the touch screen senses my touch in reverse - when the tablet is in horizontal position and if I touch at the bottom(x,y) , it exactly sense at the upper half of the touch screen but accurately (-x,-y)
-SB
2014/12/06 - 10:38
Pls check this (install via CWM): http://crewrktablets.arctablet.com/?wpfb_dl=2288
patdut
2014/12/06 - 12:41
Hello Oma,
I have a little question about this ROM. I own an AOSON M33 without any Q after the M33. Does this rom is compatible with my device ?
Thank you for your answer.
Patrick from Volvic France
2014/12/06 - 15:32
No, its not compatible. Can I see a dmesg log?
patdut
2014/12/06 - 16:02
Here is the dmesg result:
2014/12/06 - 17:04
I need a log from 0.000000 sec on. Boot tab fresh and try again.
patdut
2014/12/06 - 17:38
This is the earlier result of dmesg I can have. Just after I get control with Android terminal.
74 Guest(s)
Devices in use: Desktop (70), Phone (4)
niteaura
radolini
fede32
Ty3uK
pipirska
telo000788
