This is a generation 2 loader KK build for high-resolution tabs and RTL8188 wifi  Â
update 05.01.2015:
new hardware revision in the field, called GB:Â here is the kernel (change in folder rockdev/Images before flash)
– system ext4
– selinux kernel ok #4 preempt 09.05.2014
– internal storage 4 GB
– ethernet support
– init.d support
– gameloft compatible
– USB-Hub enabled
– Dateimanager HD (Root)
– Nova Launcher
Gen2 loader firmware will frequently generate trouble for the user. So, please read
the instructions carefully to understand how to change between gen1 (v1.24 loader)
and gen2 (v2.10 loader) firmware.
hints:
– to improve UI feeling disable animation scales in developer options
– to disable su notifications change notification in su app
– to prettify the build use Xposed Framework > Starterpack
 – Oma -
gagouPer aspera ad astra, we rock the Tablets !
No, these tabs have MT5931 wifi.
No, there is no selinux kernel available for N80RK.
Maybe you can try the latest CM11 build: http://crewrktablets.arctablet.com/?p=3591
Use your kernel and the 160dpi fix.
2014/08/23
I have successfully installed this firmware on my M33Q. It works well and is responsive. Thanks Oma for this great work !
However, because I have the M33QS (gb version), X axis is inverted. I haven't found an app or a config file to correct it. Is it possible to have an alternate kernel for this version ?
Thanks in advance !
Does it rotate and is it only a wrong orientation?
2014/08/23
The screen rotation is ok. The trouble is with the touch screen. If you are in landscape orientation, the vertical axis is inverted (if you touch the top, the system thinks you touch the bottom). Same thing in portrait orientation, but with horizontal axis.
I tried this solution , but adb doesn't recognize my tablet (on windows or linux).
2014/08/23
Ok adb is ok now (my sdk was too old).
Here is the dump of lsmod :
cdc_acm 13266 0 - Live 0x00000000
ftdi_sio 29129 0 - Live 0x00000000
pl2303 10561 0 - Live 0x00000000
cp210x 11073 0 - Live 0x00000000
snd_usb_audio 75637 0 - Live 0x00000000
snd_usbmidi_lib 15884 1 snd_usb_audio, Live 0x00000000
snd_rawmidi 15636 1 snd_usbmidi_lib, Live 0x00000000
snd_hwdep 4944 1 snd_usb_audio, Live 0x00000000
md4 3319 0 - Live 0x00000000
cifs 245765 0 - Live 0x00000000
rtl8150 8447 0 - Live 0x00000000
mcs7830 5049 0 - Live 0x00000000
dm9601 5600 0 - Live 0x00000000
tcp_veno 1409 0 - Live 0x00000000
isofs 30335 0 - Live 0x00000000
udf 69910 0 - Live 0x00000000
sr_mod 12988 0 - Live 0x00000000
sg 20434 0 - Live 0x00000000
cdrom 33656 1 sr_mod, Live 0x00000000
cuse 4129 0 - Live 0x00000000
crc_itu_t 1059 1 udf, Live 0x00000000
hubenable 565 0 [permanent], Live 0x00000000
rk29_ipp 9957 1 - Live 0x00000000 (C)
mali 152580 35 - Live 0x00000000
ump 30472 17 mali, Live 0x00000000
rk30xxnand_ko 162075 0 - Live 0x00000000
I don't know which one manages the touchscreen. I tried to mount the boot partition (/dev/block/mtd/by-name/boot) but without success.
Can you pls test (install via CWM): http://crewrktablets.arctablet.com/?wpfb_dl=2057
Fakerotation is only for the bootanimation. Download again and test: http://crewrktablets.arctablet.com/?wpfb_dl=2057
2014/08/23
Thanks for your time Oma. Unfortunately no progress with your last patch, it only has an effect on the auto rotate.
I did some research and I saw this in dmesg :
input: ct36x_ts as /devices/virtual/input/input1
But this module isn't in lsmod output. I found some source code here about ct36x_ts module and in Kconfig I found TOUCHSCREEN_CT36X_MISC_Y_REVERSE option. So it could worth a try. Is it hard to create a custom kernel (build and install) ?
Without sources nearly no chance.
Tab should now boot in portrait. Mirrored touch in this position?
2014/08/23
Yes, still mirrored in portrait position. But with horizontal axis now.
I will try to compile the kernel. Did you build the one included in your rom ? Or where did you find it ?
I will start with this source code, but if I could have the .config file used by your current kernel, it will make this task easier (/proc/config.gz doesn't exist in your rom).
66 Guest(s)
Devices in use: Desktop (57), Phone (9)
wemiy54158
sidor
houssmen
qarolus
dav512
tgergely2012
