Simple tool to Root and Dump the stock firmware via PC.
If you'd like you can upload the files and post a link here. I will check if anything is ok.
2014/12/18
Hi Oma7144, I have a "Samsung" branded Quad Core 2.0GHz Tablet Model P9700 9.7 inch Screen Android 4.4.2 DDR GB HD 64GB, Processor Model:Cortex-A9 and RK3188, Kernel Ver. 3.0.36+ dont@dont #319 and would like to know if you have a custom Rom and or Kernel for this model? See here http://www.aliexpress.com/snapshot/6196101760.html?orderId=63459989040522 I could upload the backed up files for you.
This is the same looking model as the e-ceros revolution model in Post 1, only on mine the front and rear cameras are 5mp and 8 mp.
Yes, pls upload the files. I will check.
2015/03/31
Hello dear Oma, i trying to port your firmware with android 4.4.2 RK3188 on my tablet DNS M100qw RK3188, everything works except wifi, i have chip - mt6620 combo driver; I copied all modules from stock in port(system/lib/modules), edited init.rc from port - added lines about mt6620 from stock; lsmod showed me - all modules run, exactly as stock firmware, but wifi is not work, help please, i can send you dmesg log from port and from stock:)
2015/05/04
Hi Oma7144 ,
I have a Tolino Tablet 8.9 that i am trying to Root . I followed your steps but i still cannot root it .
Tried win 8.1 and 7 . Any help will be apreciated . I am not very proficient when it comes to Android and ADB and things like that so please try and dumb it down for me . I only got the basics down .
From the message i thinks there is something wrong and it is not recognising the tablet . The tolino info is M/N TT89416-1 , Android 4,2,2 Kernel 3,0,36+ jack-liao@rd-sw-server 2 #180 Build nr Tolino89,v01,01,03,20140122
This is what i get .
ROOT
Please wait...
'adb' is not recognized as an internal or external command,
operable program or batch file.
operable program or batch file.Push su and busybox!
operable program or batch file.Install SuperSU
operable program or batch file.Install RebootMenue
operable program or batch file.ROOT completed!
Press any key to continue . . .
Simple tool to Root and Dump the stock firmware via PC.If you'd like you can upload the files and post a link here. I will check if anything is ok.
Hello cyrusone,
From the errors you reported it looks like that adb is not in your path or not properly installed.
You'll have to fix that before running Oma's tool again. The problem (and the fix) should be similar to this one:
2013/06/20
I do have problems with root of an Odin.
If not started as ADMIN nothing happens at all - so just daemin started successfully.
If started as admin, I get the following - see above.
I found that different adbs are involved. Started your batch without admin it seems to operate with the local adb and does nothing.
With another one I can connect, but the adb remount command fails. ?!?
With the other (in general working) adb I get this message:
adb server version (29) doesn't match this client (36). Not sure what is server and client here ...
2013/06/20
I tried this with another Win7 x64 PC with no adb installed before. Although driver installer gives feedback "ok", it wasn't. Device wasn't recognised. It give feedback of two unknown devices , one IRON one MTP.
I tried to install ADB and Rockchip driver manually. But don't get adb connection.
Can you help me and show how does it looks like in devicemanager if this is fine? Do I have to do more than enable USB debugging? I am wondering - is is as easy just with adb remount to make system writable? Nothing to be done to unlock this?
With the great collection of tool, scripts and driver I thought this is easy-peasy, but it seems not in my case....
2017/10/15
Hi Oma,I have an Medion S7851 Tablet.
Here the link to my firmware dumb: https://drive.google.com/folderview?id=0B4Fpa0xELHobQTdoZ01aOEQwZ0E
I hope you can provide a custom Rom for this tablet. Regards omnia
2017/01/18
pls help
I need a custom ROM(android 5 or later) for the tablet Texet mt-9768HD
It's current ROM
ِDownload offical Rom : http://digitalpro.persiangig.com/Q973C_TEXET_V1.3_20131125_update_9768HD.rar/download
68 Guest(s)
Devices in use: Desktop (59), Phone (8), Tablet (1)
hakhiem
jenom
kfwacky
fer30
culo1
dfrt
