RK31: Xoro PAD 9719QR KitKat Edition --> installation on a 9720...
Tried it install on a Xoro PAD 9720QR, not working..
cholera
2014/07/12 - 23:00
Hi!
I have a Xoro PAD 9720RQ and was running a rooted 4.2.2
I wanted to try the "RK31: Xoro PAD 9719QR KitKat Edition"
 from http://crewrktablets.arctablet.com/?p=3319
downloaded all files, but did not find the Kernel #132
QR Clones (pls use included kernel #132)
Tried anyways ;)
installation went good, rebooted to cwm.
I should install the format_NAND_KK fix,
12. run format_NAND_KK fix (install zip from ext_sdcard)
but I got the error:
cannot mount /external_sd
cannot mount /sdcard
Tried a reboot.
WayteQ logo. OMA logo.. nothing more..
When entering CWM again, i even cannot recover my previous  ROM, as the sd is not found.. :(
What can I do now?
2014/07/14 - 16:39
Flash again. Make sure the external sdcard is in the tab before flash.
cholera
2014/08/03 - 13:14
Hi!
After a few weeks of trouble with the kids and holidays i finally had time for a second try.
Working now!
Thanks!
Cholera
hv11225
2014/12/30 - 15:43
Sieht auf den ersten Blick perfekt aus. Vielen Dank fĂĽr die Arbeit!
2014/12/30 - 15:57
Fine.
98 Guest(s)
Devices in use: Desktop (88), Phone (10)
hans41
rickybk
soniya07
ironmangitar
