[REQUEST] MIUI for Odys Iron
th3ma5k3
2014/09/02 - 15:00
Hello erverone,
i have a Odys Iron since march and i´m using the custom roms of  oma (a big thanks for his work), since this days. I´m not realy a android developer so i´m asking if some can modify the MIUI rom, that i can use it on my Odys Iron, yes i know it´s a lot of work but it would by realy great and i think there are some more people with would like to use this rom on the Iron.
I found this page but i don´t know what to do with this, can i install it on my odys? its also RK3188...
TH3MA5K3
JochenKauz
Forum Posts: 450
Thanks Received: 76
2014/09/03 - 01:26
I'm really sorry.. we have no experience in MIUI
2014/09/06 - 21:21
I spent a few hours on that to make MIUI run on Iron: http://forum.xda-developers.com/showpost.php?p=53325034&postcount=1778
If you'd like I can upload the system.img.
th3ma5k3
th3ma5k3
2014/09/27 - 21:38
it wood be great if u can so this and lots of thanks for the work :)
sry for my late replay
@oma are u german? because of the language in the pictures :)
JochenKauz
Forum Posts: 450
Thanks Received: 76
2014/09/28 - 15:58
complete crew is a german one.
Cheers
JochenKauz
2014/09/28 - 16:36
Ok, hier ist das system.img: http://crewrktablets.arctablet.com/?wpfb_dl=2140
Das ist KitKat und braucht den gen2 loader, sollte also in dieser Umgebung hier laufen: http://crewrktablets.arctablet.com/?p=3622
Wie du den Loader tauschst, ist in der Anleitung beschrieben. Bitte unbedingt beachten!
Ansonsten system.img und kernel.img austauschen. Achja du brauchst noch einen selinux kernel ;-)
yao85930101
2014/10/13 - 08:55
My MINI ONE ZZ tried for a long time still can not boot, the MINI ONE does not support it?
I hope to help I really like this ROM
Before I send you XDA, but it has not been news.
2014/10/13 - 15:48
Sorry again. There is no selinux kernel for the Mini One. Consequently the build will not boot on your tab.
yao85930101
2014/10/14 - 03:14
Thank you very much for your reply, there is no way to help get a selinux kernel.
2014/10/14 - 07:19
Unfortunately not. Vido never published kernel sources.
But hey ... I guess you are Chinese, too. They do not think in dimensionen like "supporting things a long time". Two or three production batches, maybe a bug fix firmware ... and forget.
yao85930101
2014/10/14 - 09:10
Oh, I see.
92 Guest(s)
Devices in use: Desktop (83), Phone (9)
hans41
rickybk
soniya07
ironmangitar
