REQUEST: 4.4KK Rom for Cube U39GT / Iconbit Thor ZX
killain
Forum Posts: 15
61
2014/06/29 - 01:36
OK. Sorted the SD card issue. I needed to format the nand using the tool on the main page.
link
Also do not require a larger parameter now. I have found a program that will transfer large games to the external SD card. The app is called folder mount and can be found in Google play store.
vasil_d
Forum Posts: 74
Thanks Received: 50
62
2014/06/30 - 07:00
Hello guys.
Sorry but I did not have time (work related trip) so I have not completed my promise to work on the rom/image.
First things first.
primus good job for the  cameras. If you want attach the files and ill test them later.
killain- I am attaching the 8G parameter file. I'm very interested how many apps and sizes do U use :-)
dinindourden - nice find. I think we have to edit the vfstab file to mount the partitions at boot. I have experience with the linux fstab but I will check the vfstab later.
Hope I will have the time this week.
The following users say thank you to vasil_d for this useful post:
primus, killain
killain
Forum Posts: 15
63
2014/06/30 - 19:44
Thank you very much for the parameter file vasil_d.
Walking dead the game is 1.3gb in size. It contains 6 chapters as in app purchases which adds another gb. As you can see a couple of games like that can take up a lot of storage space.
Can you please tell me if it is very complicated to create a parameter file and if not how do you do it? I would like to try for other tablets.
vasil_d
Forum Posts: 74
Thanks Received: 50
64
2014/07/01 - 06:53
Copy/Paste from other source:
Bottom line each .img or partition setup is proceeded by it size and then offset into the ROM file.  For instance  0x00002000@0000000(boot), 0x00080000@00002000(kernel), 0x0004000@00082000(cache)
The number is the size@offset.  So first img starts at 0 and is 2000 is size.  The the next one after it starts at offset 2000 and is 80000 in size.  So on and so forth.
The numbers are in HEX mode. Allso you are not suppose to rearrange the content, just modify it.
killain
Forum Posts: 15
65
2014/07/01 - 21:09
Thanks for the response vasil_d. So I need to use a hex editor to get the values?
vasil_d
Forum Posts: 74
Thanks Received: 50
66
2014/07/01 - 21:38
To primus (an all interested at all).
Today I did disassembled (again for the n-time) my cube U39gt. The reason for that this post/threat (http://forum.xda-developers.com/showthread.php?t=2600789)
In short terms I identified the NAND and RAM modules - exact speeds, timings and voltages.
The board is model U9GT3_V05. The nand is Hynix and RAM is SCSemicon. NAND modules aside.
The Ram is HXB15H4G800BF–15H meaning it is DDR3 at 667 (1333) MHz with timings 9–9–9. The voltages are 1.5 V ± 0.075 meaning it is not low voltage model.
In the XDA treath a very nice suggestion about decreasing the CPU/GPU stepping scaling is suggested.
So primus, are you able to give me the exact stepping for the CPU/GPU speeds and voltages.
What I suggest is to make/mod the stock 1.06 kernel reduce the stepping speeds for CPU and GPU.
We can assume that a safe overclock speeds and voltages are - for GPU speed is 550Mhz @ 1.25, CPU speed 1600Mhz@1.3 V  and RAM speeds 667@1.5V
For CPU maybe we can use this stepping
504mhz @ .925v
1008mhz @ 1.075v
1416mhz @ 1.250v
1608mhz @ 1.300v
For GPU maybe we can use this stepping
200mhz @ 1v
400mhz @ 1.100v
533mhz @ 1.250v
RAM like I did write before 667@1.3V
Primus, if you are able to get the default stepping for the clocks and voltages from the kernel pleas post them.
EDIT: To killain - yes you can use the stock/build in Windows 7 calculator.
killain
primus
Forum Posts: 19
Thanks Received: 10
67
2014/07/02 - 16:04
vasil_d => Stock values & settings of Cube 1.06 Kernel  (same values in 1.04 & Iconbit Kernels ) =>
CPU:
312Mhz@0,950v
504Mhz@0,950v
816Mhz@1,000v
1008Mhz@1,075v
1200Mhz@1,200v
1416Mhz@1,250v
1608Mhz@1,300v
GPU:
133Mhz@0,975v
200Mhz@1,000v
266Mhz@1,025v
300Mhz@1,050v
400Mhz@1,100v
600Mhz@1,200v
RAM:
528Mhz@1,275v
For the libs of 2 Cameras i post them later because i'm not at home. And i see the same post in XDA and test reduce steps on CPU & GPU in my OC kernel CPU 504-1008-1416-1608-1800    & GPU 400-600-798 => Results: a little more responsive and not draining battery too much between stock Cube settings.
PS: Vasil_d => if you want i can mod the Cube kernels (1.04 & 1.06) with your settings
The following users say thank you to primus for this useful post:
killain
vasil_d
Forum Posts: 74
Thanks Received: 50
68
2014/07/02 - 21:27
Primus => Thanks man. I was unable to make the perl script to work. Did not have the time also.
So pleas make me a stock kernel 1.06 with the following settings/stepping for tests:
CPU:
504Mhz@0,950v
1008Mhz@1,075v
1416Mhz@1,250v
1608Mhz@1,300v
GPU:
200Mhz@1,000v
400Mhz@1,100v
600Mhz@1,200v
RAM:
667Mhz@1,300v
I guess there is no easy way to add more CPU governor like SmartAssX right?
primus
Forum Posts: 19
Thanks Received: 10
69
2014/07/03 - 11:31
I provide you in attachements, two version with your settings, because this kernel don't got the 667Mhz Table but 600 or 720 :/. For the Gorvernors, i can't because we don't have the source of cube's kernel for recompiling (and modding) the entire kernel :/.
I found anothers sources for RK3188 (Raxda Rock, Crewtablet team, Omegamoon) for creating brand new kernel for us. But i don' have enough time for the next three  days, maybe this WeekEnd.
Anyone got the entire GPIO log on this tab, because is vital for creating new kernel ? If anyone don't got them i checking GPIOs modules myself this WeekEnd.
Have fun ;)
killain, vasil_d
killain
Forum Posts: 15
70
2014/07/03 - 13:36
Will these kernels work on the kit kat rom?
primus
Forum Posts: 19
Thanks Received: 10
71
2014/07/03 - 14:03
Yes, they're works on KitKat(4.4.2) & JB(4.2.2).
NOTA: For thoses who want test these kernels. They're on IMG format, so don't try to install them with CWM ;).
killain
vasil_d
Forum Posts: 74
Thanks Received: 50
72
2014/07/03 - 15:44
Primus, thanks for the last modified kernel.
For 2 H usage it is behaving very well.
primus
dinindourden
Forum Posts: 14
73
2014/07/04 - 06:23
I tried the kernels and after 30 minutes of use I had screen freeze and power off.
It seems like only the stock kernel works for me. With other kernels screen freezes, shatters and device power off on gpu activity. e.g. games, movies, ebooks and browsing.
This doesn't affect everyone, so it might be, that some models have different type of hardware, or faulty hardware.
74
2014/07/04 - 07:01
No, everything is ok with your tab. OC will lead to instability in any case. There might be 5-10% of the whole rk3188 popoluation which can run @ 1,7 GHz.
Anyway, it is not the idea to run the CPU @ max speed. Normal CPU usage is only two steps: 312 and 816 MHz.
cpu.php_.pngImage Enlarger
primus, Jonok
killain
Forum Posts: 15
75
2014/07/04 - 12:09
Thanks for the kernels primus.  I have used the ddr720 kernel and everything is running fine with nearly 3 hours of usage. No instabilities. General use and game playing running smoothly.
Seems faster than the stock kernel.
The following users say thank you to killain for this useful post:
primus
105 Guest(s)
Devices in use: Desktop (93), Phone (12)
laca76
ghamed
swan12
