REQUEST: 4.4KK Rom for Cube U39GT / Iconbit Thor ZX
Thanks Received: 1385
2014/06/15 - 19:42
No, the ft5406.ko is not running.
Try to load it manually:
insmod /system/lib/modules/ft5406.ko
lsmod
Jonok
kadwish
Forum Posts: 11
2014/06/15 - 20:06
I get
insmod: init_module '/system/lib/modules/ft5406.ko' failed (File exists)
(I did go to that directory and sure enough the file IS there.)
2014/06/15 - 20:19
Maybe somebody can upload a dmesg and a logcat log of the stock firmware. And also the result of "lsmod". Thanks!
kadwish
Forum Posts: 11
2014/06/16 - 05:01
1.06 stock firmware
lsmod:
wlan 458451 0 - Live 0x00000000
gt9xxdrv 22801 0 - Live 0x00000000
vpu_service 11717 0 - Live 0x00000000
rk29_ipp 9957 0 - Live 0x00000000
mali 112485 9 - Live 0x00000000
ump 29254 19 mali, Live 0x0000000
rk30xxnand_ko314328 0 - Live 0x00000000
I need some direction on obtaining a proper logcat as the ones I am obtaining are very very short and not complete.
killain
Forum Posts: 15
2014/06/16 - 16:49
kadwish said
1.06 stock firmware
lsmod:
Enter into terminal emulator,
Su
Logcat -d -v time >/mnt/sdcard/logcat.txt
killain
Forum Posts: 15
2014/06/16 - 16:56
I'm running the iconbit stock firmware v1.1
dmesg
logcat
lsmod
Thanks for looking at this for us Oma7144.
2014/06/16 - 16:59
kadwish said
1.06 stock firmware
lsmod:
input: Goodix Capacitive TouchScreen as /devices/virtual/input/input4
You guess in post #7 was f5406.ko, but logs shows it is gt911.ko.
Normally there is also a binary file needed, which is not included in the stock firmware:
busybox cp /system/lib/modules/gt911.bin /data/goodix/_goodix_update_.bin
I'd like to see a logcat, pls.
kadwish
Forum Posts: 11
2014/06/16 - 18:27
Factory 1.06 20130928
Kernel version 3.0.36+ cb@cb-eyes #77
-Kadwish
2014/06/16 - 19:09
Ok, touch controller firmware isn't there in the stock firmware.
Download again and try: http://crewrktablets.arctablet.com/?wpfb_dl=1826
kadwish
vasil_d
Forum Posts: 74
Thanks Received: 50
2014/06/16 - 21:30
Hi guys.
I want to join the threat.
If I am able to help in any way just tell me.
I have linux background and some android moding experience. I allso own 2 pcs of Cube U39GT.
I did tried to port iFive X2 4.4 rom to our Cube but no luck.
Hardbricked the device twice but after opening it and short circuiting 2 terminals to enter MASK mode I did recover successfully.
So again, If you need testers or something ....
The following users say thank you to vasil_d for this useful post:
Jonok, killain
2014/06/17 - 16:00
Thanks vasil_d. The fix in post #24 should do the trick.
vasil_d
Forum Posts: 74
Thanks Received: 50
2014/06/18 - 10:38
Today I tested the suggested methods.
I did make several attempts and ways of doing the flash and some mods.
The touch is still not working even after the fix in post 24.
Later (after getting my OTG cable) Ill write the lsmod log.
P.S. Having some troubles obtaining root privileges. Suggestions?
Jonok, killain
killain
Forum Posts: 15
2014/06/19 - 00:21
Try using the following for root.
root enabler
vasil_d
Forum Posts: 74
Thanks Received: 50
2014/06/19 - 08:10
Root not working. Anyways.
Here is the lsmod log:
rk29_ipp 9957 1 - Live 0x00000000 (C)
mali 152932 45 - Live 0x00000000
ump 28166 21 mali , Live 0x00000000
rk30xxnand_ko 3143280 - Live 0x00000000
dmesg log not able to be obtained without root.
Logcat log is attached.
gt911.ko is present in system/lib/modules folder. gt911.bin is not in system/lib/modules
Maybe there is some error while executing the shell script tp_detect.sh
2014/06/19 - 08:27
The build is rooted. Flash again first.
Insmod the gt911.ko.
62 Guest(s)
Devices in use: Desktop (54), Phone (8)
yung1961
ondateste
lilila3
Anatrop
antoniors021
wemiy54158
