REQUEST: 4.4KK Rom for Cube U39GT / Iconbit Thor ZX
manu_katz
Créteil (France)
Forum Posts: 19
196
2014/12/29 - 02:05
Hi vasil_d, sad to know that you bricked your U39GT 'cause it's thanks to you if I use KitKat without problem on my own tab.
Didn't you said that you got a tip to unbreak a bricked one :
vasil_d said
Hardbricked the device twice but after opening it and short circuiting 2 terminals to enter MASK mode I did recover successfully.
tofclaire
France
197
2014/12/29 - 12:05
vasil_d said
Hi guys.
I want to inform you that I am stopping the development of roms for the U39GT.
I was on the finishing line of posting a 4.4 KK release V1.0 with hybrid kernel and tweaks but my tablet did brick.
I am experiencing NAND problems with the device. Not able to write to the NAND memory. I did a MASK mode flash but I did not fix the problems.
So i want to share my final thoughts about this device:
PROS:
- BY FAR the best screen that I have used and viewed (brightness, resolution and view angles)
- very good capacitive touch
- good and long lasting battery
- good overall build quality (front, back and assembly)
CONS:
- the RK3188 Kernel and android SUCK. Period
- the weak wifi reception
- the slow overall feel - thanks again Rockchip
One last thing from me - If you want to buy a CUBE tablet buy it, BUT TAKE IT WITH MTK chipset. That is wath I am going to do some day when I decide to spend again aprox 200 USD :-)
sad to read that... thank you so much for your work
sorry for my bad english
vasil_d
Forum Posts: 74
Thanks Received: 50
198
2014/12/29 - 20:39
I did recover the tablet befoore from hard brick - meaning no bootloader, no MBR nothing (empty NAND chips).
Now I have problems with NAND writes (hardware/chip is) unable to write (change states) of the memory cels.
Any ways. Now the el. engineer in me is waking up again and I have decided to use the screen on my RaspberyPi or mount another mainboard to this screen some day / some how.
If I have any progress I will write.
vasil_d
Forum Posts: 74
Thanks Received: 50
199
2014/12/29 - 20:47
Thermaltake said
Anyone ?
Do a hard brick recovery. Meaning:
1. Power off the tablet and open it
2. Unplug and plug the battery connector
3. With a needle short circuit pins 7 and 8 of the nand chip
4. Run the flash software and load the image with the rom (or do it before step. 3)
5. While holding the VOL+ and PWR buttons and plug the USB cable.
6. In the RKbatchtool the square 1 box should be BLUE (i think)
7. Press restore button.
If that flash mode is not successfull the you allso have another problem.
Thermaltake
200
2014/12/29 - 21:11
vasil_d said
Thermaltake said
Anyone ?
I did it from mask mode too and same thing, black screen with lights, and I try to do short circuit when that recovery is blinking from time to time hoping that It will show eventually like stock rom did when I restore it, but no luck. I was doing pin trick for like 45mins and nothing, and when I restore stock rom I took me like max. 5mins to restore screen with pin trick.
vasil_d
Forum Posts: 74
Thanks Received: 50
201
2014/12/30 - 21:29
Hallo again guys.
I have a final request to PRIMUS.
So Primus may I ask you to do one small kernel mode for me.
Pleas make me a 1.06 kernel mode with the following setting bellow using rkpatchomatic tool.
Here are the settings:
CPU values - MHz @ Voltage
504@0.950
816@1.000
1008@1.075
1416@1.250
GPU values - Mhz @ Voltage
200@1.000
400@1.100
600@1.200
600@1.300 (or 1.275v if 1.300v is not available value)
If you do not have the IMG file with the kernel you cann download it from here:
http://debian-administrator.eu/images/Articles/Android/U39GT/KERNELS/kernel_Cube_U39GT_Stock_1.06.img
ivrugar
202
2014/12/31 - 17:08
Happy New Year to all
I am also sad because vasil_d can not develop ROM for u39gt Cube.
After many tests, I decided to install Kasty ROM because it is the most compatible with the app. At the same time I flashed the vasil_d's Kernel ROM 4.4.
The result has been wonderful because the tablet works very fast. The problem is it's too unstable.
Vasil_d, you could do a better Kernel?
rsgomes
203
2015/07/08 - 20:38
is there any new rom for cube u39gt?
rugalcs
204
2015/09/11 - 18:04
Hello to all!
I have arrive to this post today, and after reading all the posts, I see that any link for any roms works, all are down.
Anyone could upload some rom of the latest 4.4 vasil_de rom or the modded 4.2.2 rom from previous posts?
Thanks!
Edit: Here is the working link! : https://www.debian-administrator.eu/android/cube-u39/
Currently Online: 2256667898, mogabi
92 Guest(s)
Devices in use: Desktop (84), Phone (10)
mogabi
ryb84
smoky551
KarlAnkho
jasondweller
2256667898
